今天弄了一天的GPIO复用功能。。。书上说要配置GPIOPCTL寄存器。我翻了好久发现只要库函数中的void
GPIOPinConfigure(uint32_t ui32PinConfig) 这个函数涉及到了这个寄存器。。。。。。可是,可是,可是!!!!!!这个函数的参数该写什么啊???????找不到宏,有木有。。。。翻阅datasheet...。。。。。。。。发现在 1346页有这个表格:Table 23-5. GPIO Pins and Alternate Functions
还有前面有这么一句话 Further pin muxing options are provided through the GPIO Port Control (GPIOPCTL) register which
selects one of several peripheral functions for each GPIO. For information on the configuration
options, refer to Table 23-5 on page 1346.
Note: If any pin is to be used as an ADC input, the appropriate bit in the GPIOAMSEL register
must be set to disable the analog isolation circuit.
本来英语就捉急,好不容易翻阅到了这一步。。。。。可还是不知道他妈的这个函数的参数该怎么写。。。。。。。。
