4433|0
336
LPC1500体验+之四_串口调试接收数据成功 [复制链接]
首先是配置串口引脚,选择的是串口0.
/* UART Pin mux function - note that SystemInit() may already setup your
   pin muxing at system startup */
static void Init_UART_PinMux(void)
#if defined(BOARD_NXP_LPCXPRESSO_1549)
        /* UART signals on pins PIO0_13 (FUNC0, U0_TXD) and PIO0_18 (FUNC0, U0_RXD) */
        Chip_IOCON_PinMuxSet(LPC_IOCON, 0, 13, (IOCON_FUNC0 | IOCON_MODE_INACT | IOCON_DIGMODE_EN));
        Chip_IOCON_PinMuxSet(LPC_IOCON, 0, 18, (IOCON_FUNC0 | IOCON_MODE_INACT | IOCON_DIGMODE_EN));
        /* UART signal muxing via SWM */
        Chip_SWM_MovablePortPinAssign(SWM_UART0_RXD_I, 0, 13);
        Chip_SWM_MovablePortPinAssign(SWM_UART0_TXD_O, 0, 18);
#else
#warning "No UART nmuxing defined for this example"
#endif
同时打开三色led灯,进行相应的测试指示。
        Board_LED_Set(0, false);
        Board_LED_Set(1, false);
        Board_LED_Set(2, false);
串口初始化配置:
        /* Setup UART */
        Chip_UART_Init(LPC_USART);
        Chip_UART_ConfigData(LPC_USART, UART_CFG_DATALEN_8 | UART_CFG_PARITY_NONE | UART_CFG_STOPLEN_1);
        Chip_UART_SetBaud(LPC_USART, UART_TEST_DEFAULT_BAUDRATE);
        /* Optional for low clock rates only: Chip_UART_SetBaudWithRTC32K(LPC_USART, 300); */
        Chip_UART_Enable(LPC_USART);
        Chip_UART_TXEnable(LPC_USART);
        /* Before using the ring buffers, initialize them using the ring
           buffer init function */
        RingBuffer_Init(&rxring, rxbuff, 1, UART_RB_SIZE);
        RingBuffer_Init(&txring, txbuff, 1, UART_RB_SIZE);
        /* Enable receive data and line status interrupt */
        Chip_UART_IntEnable(LPC_USART, UART_INTEN_RXRDY);
        Chip_UART_IntDisable(LPC_USART, UART_INTEN_TXRDY);        /* May not be needed */
        /* Enable UART interrupt */
        NVIC_EnableIRQ(LPC_IRQNUM);
        /* Initial message sent using blocking method to prevent ring
           buffer overflow */
        Chip_UART_SendBlocking(LPC_USART, inst3, sizeof(inst3) - 1);
        Chip_UART_SendBlocking(LPC_USART, inst1, sizeof(inst1) - 1);
        Chip_UART_SendRB(LPC_USART, &txring, inst2, sizeof(inst2) - 1);
其中inst1,2,3的三个数据为:
const char inst3[] = "\r\nyouzizhile test lpc1549 xpresso v2 uart!  \r\n";
const char inst1[] = "LPC15xx UART example using ring buffers\r\n";
const char inst2[] = "Press a key to echo it back or ESC to quit\r\n";
接收PC的串口数据,如果为2,则进行相应的led灯指示:
Chip_UART_Read(LPC_USART, &data1,1);
if(        data1==0x30)
       Board_LED_Toggle(0);
if(        data1==0x31)
       Board_LED_Toggle(1);
if(        data1==0x32)
      Board_LED_Toggle(2);
串口显示结果:
红色为在原文件上的修改部分。
LPC1500体验+开发环境的构建
LPC1500体验+驱动步进电机设计
LPC1500体验+led闪烁
此帖出自NXP MCU论坛
个人签名每一刻都是崭新的,加油!
