4062|6
336
LPC1500体验+之三_led闪烁 [复制链接]
自从安装驱动和更新debug 镜像成功后,就迫不及待的设计程序。首先是下载最新的示例代码:
参照蓝雨夜的帖子@蓝雨夜 编译相应的程序生成chip_15xx_lib.lib和board_nxp_lpcepresso_1549.lib,然后设置periph_blinky为活动工程,但是编译时总是说board_nxp_lpcepresso_1549.lib无法打开或者文件不存在,尝试了很多次都是同样的问题,而chip_15xx_lib.lib没有类似的问题。
然后就把生成的board_nxp_lpcepresso_1549.lib移动到另外一个路径不是很深的文件夹,删除原来的文件,这次编译成功。
在main函数添加以下几句话,控制三个灯同时闪烁。
        Board_LED_Set(0, false);
        Board_LED_Set(1, false);
         Board_LED_Set(2, false);
同时要修改
中断控制程序:
* @brief        Handle interrupt from SysTick timer
* @return        Nothing
void SysTick_Handler(void)
        Board_LED_Toggle(0);
        Board_LED_Toggle(1);
        Board_LED_Toggle(2);
然后三个灯同时闪烁。
几个相关led控制函数的原型如下:源文件在board.c中
#define MAXLEDS 3
static const uint8_t ledpins[MAXLEDS] = {25, 3, 1};
static const uint8_t ledports[MAXLEDS] = {0, 0, 1};
/* Initializes board LED(s) */
static void Board_LED_Init(void)
        int idx;
        for (idx = 0; idx < MAXLEDS; idx++) {
                /* Set the GPIO as output with initial state off (high) */
                Chip_GPIO_SetPinDIROutput(LPC_GPIO, ledports[idx], ledpins[idx]);
                Chip_GPIO_SetPinState(LPC_GPIO, ledports[idx], ledpins[idx], true);
/* Sets the state of a board LED to on or off */
void Board_LED_Set(uint8_t LEDNumber, bool On)
        if (LEDNumber < MAXLEDS) {
                /* Toggle state, low is on, high is off */
                Chip_GPIO_SetPinState(LPC_GPIO, ledports[LEDNumber], ledpins[LEDNumber], !On);
/* Returns the current state of a board LED */
bool Board_LED_Test(uint8_t LEDNumber)
        bool state = false;
                state = !Chip_GPIO_GetPinState(LPC_GPIO, ledports[LEDNumber], ledpins[LEDNumber]);
        return state;
/* Toggles the current state of a board LED */
void Board_LED_Toggle(uint8_t LEDNumber)
        Chip_GPIO_SetPinToggle(LPC_GPIO, ledports[LEDNumber], ledpins[LEDNumber]);
/* Set up and initialize all required blocks and functions related to the
   board hardware */
void Board_Init(void)
        /* Sets up DEBUG UART */
        DEBUGINIT();
        /* Initialize GPIO */
        Chip_GPIO_Init(LPC_GPIO);
        /* Initialize LEDs */
        Board_LED_Init();
我的其它帖子:
LPC1500体验+开发环境的构建
LPC1500体验+驱动步进电机设计
此帖出自NXP MCU论坛
那看看错误的详细提示是什么问题了!慢慢找原因了!   详情 回复 发表于 2014-7-26 10:05
个人签名每一刻都是崭新的,加油!
5310
453
是不是LPCOPEN不要放中文路径,不能太深,呵呵
你编译前试着先CLEARN PROJECT看看!
我感觉用KEIL4。74来调试,总感觉有问题一样,再线调试很不方便
此帖出自NXP MCU论坛
336
我现在使用的是keil5,也试着clean project了,但是不行的,现在只有把board_nxp_lpcepresso_1549.lib放在d盘的工程路径下
此帖出自NXP MCU论坛
个人签名每一刻都是崭新的,加油!
5310
453
youzizhile 发表于 2014-7-26 08:31
我现在使用的是keil5,也试着clean project了,但是不行的,现在只有把board_nxp_lpcepresso_1549.lib放在d ...
此帖出自NXP MCU论坛
336
恩,错误说的是找不到文件或者路径不对,但是在工程中时包含这个路径的,我觉得应该是代码的路径深度太长的原因
此帖出自NXP MCU论坛
个人签名每一刻都是崭新的,加油!
336
JSD 发表于 2014-7-26 10:36
楼主 您好 看见你的板子 我流口水了  想跟你合作 做的板子
加油,共同学习
此帖出自NXP MCU论坛
个人签名每一刻都是崭新的,加油!
336
JSD 发表于 2014-7-26 11:30
谢谢 如果需要做板子的话 请联系我啊
好的
此帖出自NXP MCU论坛
个人签名每一刻都是崭新的,加油!
