4766|8
[MSP430launch pad]中断中全局变量莫名其妙被改变 [复制链接]
*  ======== ADC10 Interrupt Service Routine ========
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR_HOOK(void)
        unsigned int temp;
        float Rpt,T;
        unsigned char i;
        ADC10CTL0 &= ~ADC10IFG;
        temp = ADC10MEM;
        Rpt = (0.02659*temp+95.2381)/(0.9524-temp*1.3297*0.00001);                          //参考电压为2.5V时的转换公式
        T = (sqrt(0.39083*0.39083+0.000231*(100-Rpt))-0.39083)/(-0.0001155);
                i=T;
                LCD_pos(6,1);
                write_num( i );                                                           //温度显示
                i = T*10;
                i %= 10;
                write_string(".");
                write_data(0x30+i);
                i=0;
我在调试后发现经过ADC10的终端服务程序后,全局变量POINT的值被莫名奇妙的改了,当我注释掉ADC中断服务里面的代码后,正常运行,我怀疑是和math.h的两个函数有关,在此程序中并未涉及到关于POINT的语句,求解问题出在何处,下面是全部的程序代码:
#include
#include
#include"lcd12864.h"
#define START  BIT3            //开始
#define STOP    BIT4           //停止
#define ADD     BIT5                        //加一
#define DEC      BIT6                        //减一
#define SELECT BIT7                        //选择
unsigned int T_set;
unsigned char POINT=0,aa;
void Init(void);
void UI(void);
void KEYIE(void);
void BCSINIT(void);
void ADC10INIT(void);
void GPIOINIT(void);
void TIMERINIT(void);
void SYSTEMINIT(void);
void WDTINIT(void);
int main(void)
    Init();
        while(1)
                ADC10CTL0 |= ADC10SC;
                delay_ms(1000);
                aa=POINT;
void Init()
        WDTINIT();
        GPIOINIT();
        BCSINIT();
        ADC10INIT();
        TIMERINIT();
        SYSTEMINIT();
        LCD_Init();
        UI();
        KEYIE();
void WDTINIT(void)
        WDTCTL = WDTPW | WDTHOLD;
        /* Clear oscillator fault flag with software delay */
            do
                // Clear OSC fault flag
                IFG1 &= ~OFIFG;
                // 50us delay
                __delay_cycles(50);
            } while (IFG1 & OFIFG);
            __bis_SR_register(GIE);
        TA0CCTL1 = CM_0 | CCIS_0 | OUTMOD_7;
        TA0CCR0 = 999;
        TA0CCR1 = 499;
        TA0CTL = TASSEL_2 | ID_0 | MC_0;                                //MC_0=刚开始时不打开计时器
void GPIOINIT(void)
            P1OUT = 0;
            P1SEL = BIT2;
            P1DIR = BIT0 | BIT2 | BIT5 | BIT6 | BIT7;
            P1IES = 0;
            P1IFG = 0;
            P2OUT = BIT3 | BIT4 | BIT5 | BIT6 | BIT7;
            P2SEL &= ~(BIT6 | BIT7);
            P2DIR = 0;
            P2REN = BIT3 | BIT4 | BIT5 | BIT6 | BIT7;
            P2IES = BIT3 | BIT4 | BIT5 | BIT6 | BIT7;
            P2IFG = 0;
        ADC10CTL0 &= ~ENC;
        ADC10CTL0 = ADC10IE | ADC10ON | REFON | REF2_5V | ADC10SHT_3 | SREF_1;
        ADC10CTL1 = CONSEQ_0 | ADC10SSEL_1 | ADC10DIV_7 | SHS_0 | INCH_1;
        ADC10AE0 = 0x2;
        __delay_cycles(30000);
        ADC10CTL0 |= ENC;
void UI()
        LCD_write(1,2,"温度的测量与控制");
        LCD_flash(1);
        write_com(0x01);
        LCD_write(1,1,"当前温度:");
        LCD_write(1,2,"设置温度:");
        LCD_write(1,3,"设置时间:");
        LCD_write(7,1,".");
        LCD_write(7,1,".");
        LCD_write(8,1,"℃");
        LCD_write(8,2,"℃");
        LCD_write(8,3," s");
        //LCD_write(1,4,"");                                           //预留最后一行
void KEYIE()
        //P2IES = 0xf8;
        P2IFG = 0;
        P2IE = 0XF8;                        //        开启P2.3~P2.7的按键中断
void BCSINIT(void)
        BCSCTL2 = SELM_0 | DIVM_0 | DIVS_0;
        if (CALBC1_1MHZ != 0xFF) {
                /* Follow recommended flow. First, clear all DCOx and MODx bits. Then
                 * apply new RSELx values. Finally, apply new DCOx and MODx bit values.
                DCOCTL = 0x00;
                BCSCTL1 = CALBC1_1MHZ;      /* Set DCO to 1MHz */
                DCOCTL = CALDCO_1MHZ;
        BCSCTL1 |= XT2OFF | DIVA_0;
        BCSCTL3 = XT2S_0 | LFXT1S_2 | XCAP_1;
*  ======== PORT2 Interrupt Service Routine ========
#pragma vector=PORT2_VECTOR
__interrupt void PORT2_ISR_HOOK(void)
        P2IE &= ~0xf8;                        //关按键中断
//START键
    if(P2IFG&START)
            delay_ms(5);
            if(!(P2IN&START))
                    P1OUT ^= BIT0;
//STOP键
    if(P2IFG&STOP)
            delay_ms(5);
            if(!(P2IN&STOP))
                    __delay_cycles(1);
//ADD键
    if(P2IFG&ADD)
            delay_ms(5);
            if(!(P2IN&ADD))
//DEC键
    if(P2IFG&DEC)
            delay_ms(5);
            if(!(P2IN&DEC))
//SELECT键
    if(P2IFG&SELECT)
            delay_ms(5);
            if(!(P2IN&SELECT))
                    POINT++;
                    __delay_cycles(1);
    P2IFG = 0;
    P2IE |= 0xf8;                        //开按键中断
        unsigned int temp;
        float Rpt,T;
        unsigned char i;
        temp = ADC10MEM;
                i=T;
                LCD_pos(6,1);
                i = T*10;
                i %= 10;
                write_string(".");
                write_data(0x30+i);
                i=0;
刚才我又仔细的想了一下,感觉按键中断效率更高  详情 回复 发表于 2014-7-24 22:32
6041
199
一切的bug需要debug
刚刚发现注释掉T = (sqrt(0.39083*0.39083+0.000231*(100-Rpt))-0.39083)/(-0.0001155); 这句话后就正常了,不过不理解,还有Rpt的值Rpt = (0.02659*temp+95.2381)/(0.9524-(float)temp*1.3297*0.00001); 和我在另  详情 回复 发表于 2014-7-22 18:57
lcofjp 发表于 2014-7-22 18:52
一切的bug需要debug
这句话后就正常了,不过不理解,还有Rpt的值Rpt = (0.02659*temp+95.2381)/(0.9524-(float)temp*1.3297*0.00001);  和我在另一个工程里面算出来的不一样,这里面是2.204052e-39,根本不可能是这个值,但是由它算出的T的值却又是对的,难道中断服务程序有BUG不能进行大运算?
有可能是栈溢出了,导致的全局变量被覆盖了。  详情 回复 发表于 2014-7-22 20:19
6041
199
这句话后就正常 ...
我也这么觉得,是不是这个小数的乘除法很占用空间???  详情 回复 发表于 2014-7-22 20:30
主要是RAM太小了。  详情 回复 发表于 2014-7-22 20:44
6041
199
主要是RAM太小了。
昨天又搞了一晚上,发现是一个我自己写的函数write_num()出的问题,注释掉这个函数,RAM占用瞬间下降一半,GG,果断删掉了这个函数,瞬间恢复正常!!!!!  详情 回复 发表于 2014-7-23 10:44
闂傚倸鍊搁崐鎼佸磹妞嬪海鐭嗗〒姘e亾妤犵偞鐗犻、鏇㈠Χ閸℃ぞ绮℃俊鐐€栭崝褏绮婚幋鐘差棜闁秆勵殕閻撴洟鏌熼柇锕€鐏遍柛銈咁儔閺屻倝寮堕幐搴′淮闂佸搫鏈粙鎴﹀煡婢跺ň鏋庨柟閭﹀枤閳诲繘姊虹拠鎻掝劉闁煎綊绠栬棟濞村吋娼欐闂佸憡娲﹂崹鎵不閹惰姤鐓曢柍鈺佸暔娴狅箑顭跨憴鍕缂佽鲸鎹囧畷鎺戔枎閹存繂顬夋俊鐐€戦崝灞轿涘┑瀣瀬闁告劦鍠栭~鍛存煟濡櫣浠涙繛鍫熷劤閳规垶骞婇柛濠冩礋楠炲﹥鎯旈姀鐘插闂傚倸鍊风粈渚€鎮块崶褜娴栭柕濞у懐鐒兼繛杈剧秬椤宕h箛娑欑厪闁割偅绻嶅Σ褰掓煟閹捐泛鏋涢柡宀嬬到椤粓鍩€椤掍胶顩查悹杞拌閻庡爼鏌i幋锝呅撻柣鎾存礋閺岋繝宕掑┑鍥┿€婄紓浣哄Х缁垶濡甸崟顖氼潊闁挎稑瀚崳鏉课旈悩闈涗粶妞ゆ垵顦靛顐﹀磼閻愭潙娈熼梺闈涱檧婵″洩銇愰妸鈺傗拺閻犲洦鐓¢妤呮煕濡崵鐭掔€规洘鍨块獮妯肩磼濡厧骞堥梻浣哥秺閸嬪﹪宕㈡總绋跨闁靛牆妫涚粻楣冩煕椤愵偄澧悗姘炬嫹闂傚倸鍊搁崐鎼佸磹瀹勬噴褰掑炊椤掍礁鍓銈嗗姧缁犳垿鐛姀銈嗙厓閺夌偞澹嗛崝宥嗐亜閺傚灝顏紒杈ㄦ崌瀹曟帒顫濋钘変壕闁告縿鍎抽惌娆撴煕閺囥劌鐏犵紒鐙€鍨堕弻銊╂偆閸屾稑顏�闂傚倸鍊搁崐鎼佸磹閻戣姤鍤勯柛顐f礀缁犵娀鏌熼崜褏甯涢柛瀣ㄥ€濋弻鏇熺箾閻愵剚鐝曢梺绋款儏椤戝寮婚敐澶婄疀妞ゆ帊鐒﹂崕鎾绘⒑缂佹ê绗掗柣蹇斿哺婵$敻宕熼姘鳖唺闂佽鎯岄崹閬嶅极妤e啯鐓熼幖娣灮閸熸煡鏌熼崙銈嗗婵犵數濮烽弫鍛婃叏閻戣棄鏋侀柟闂寸绾剧粯绻涢幋鏃€鍤嶉柛銉墻閺佸洭鏌曡箛鏇炐ユい锔诲櫍閹宕楁径濠佸闂備礁鎲″ú锕傚磻婢舵劕鏄ラ柣鎰劋閳锋垿鎮归幁鎺戝婵炲懏鍔欓弻鐔煎礄閵堝棗顏�
52
52
电源解决方案和技术 | DigiKey 应用探索站
