1329|0
独家提供一体式测试探针(one body pogopin) [复制链接]
若对该品有兴趣,可致电:18915583595(carl)或email至carl@c2wide.com.
Utilizing the best attributes of each material and eliminating many individual shortcomings, instead of handmade, OBP Pin is produced 100% by fully automated machinery.
OBP pin is a very attractive, cost effective alternative for test solution.
Model No#
6538
3846A/B
3052
Type of Test
IC Test
Burn-In
IC Test
Ball Pitch
0.8/1.0mm
0.5mm
0.4mm
Pin diameter/Length(mm)
0.65/3.8
0.38/4.6
0.30/5.1
Spring Force(+/-20%)
25g@0.6mm,
25g@0.4mm  Recommended Stroke
23g@0.5mm
35g@0.8mm
Operating Temperature
-55℃~130℃
-55℃~130℃
-55℃~130℃
Current Capacity
3.0A continuous
3.0A continuous
3.0A continuous
Resistance
under 50mΩ
under 100mΩ
under 50mΩ
Band Width (S21)
-0.63dB@20GHz
-1.0dB@12GHz
 S21
file:///C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/msohtmlclip1/01/clip_image001.jpg
file:///C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/msohtmlclip1/01/clip_image003.jpg
 S11
file:///C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/msohtmlclip1/01/clip_image004.jpg
file:///C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/msohtmlclip1/01/clip_image006.jpg
