2972|0
使用CCS3.3 进行TMS320LF2407编译出现这些错误怎么解决 [复制链接]
IO_DATA                .usect                 ".data0",2                        ;I/O临时数据缓冲区
"vectors.asm", line 8:  SYMBOL REQUIRED
            LDP     #DP_PF2
"vectors.asm", line 144:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        LACL        PFDATDIR
"vectors.asm", line 145:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        SACL        PFDATDIR                ;开74HC273片选信号
"vectors.asm", line 147:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        LDP                #DP_PF2
"vectors.asm", line 151:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        SACL        PBDATDIR                ;送要显示的数据到IOPB口
"vectors.asm", line 152:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        LACL        PFDATDIR
"vectors.asm", line 153:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        SACL        PFDATDIR                ;关74HC273片选信号
"vectors.asm", line 155:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        BIT                IOSFT_REG,BIT8        ;判是否循环完一次
"vectors.asm", line 165:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                            SPLK         #81FEH,SCSR1           ;时钟4倍频,CLKIN=6 M,CLKOUT=24 M
"vectors.asm", line 182:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                     SPLK        #0E8H,WDCR                ;不使能WDT
"vectors.asm", line 183:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        SPLK        #02H,IMR                        ;使能中断优先级INT2
"vectors.asm", line 185:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        SPLK        #0FFFFh,IFR                ;清中断标志
"vectors.asm", line 186:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        LDP                #DP_EVA                        ;指向7400h~7480h区
"vectors.asm", line 187:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        SPLK        #80H,EVAIMRA        ;使能T1PINT 中断
"vectors.asm", line 188:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        SPLK        #0FFFFh,EVAIFRA        ;清EVA中断标志
"vectors.asm", line 189:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        SPLK        #0,GPTCONA
"vectors.asm", line 190:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        SPLK        #0EA6H,T1PR                ;使定时器每10 ms产生一次中断
"vectors.asm", line 191:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        SPLK        #0,T1CNT
"vectors.asm", line 192:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        SPLK        #0164CH,T1CON        ;设置通用定时器1
"vectors.asm", line 193:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        LDP                #DP_PF2
"vectors.asm", line 198:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        LACL        MCRC
"vectors.asm", line 199:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        SACL        MCRC
"vectors.asm", line 201:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        LACL        MCRA
"vectors.asm", line 202:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        SACL        MCRA
"vectors.asm", line 204:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        LACL        PFDATDIR
"vectors.asm", line 205:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        SACL        PFDATDIR
"vectors.asm", line 208:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        LACL        PBDATDIR
"vectors.asm", line 209:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        SACL        PBDATDIR
"vectors.asm", line 211:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                         LDP                #DP_PF2
"vectors.asm", line 235:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                         LACL        PFDATDIR              ;取出键值PFDATDIR.3玃FDATDIR.6
"vectors.asm", line 236:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        LACC        PIVR,1                        ;读取外设中断向量寄存器(PIVR),并左移一位
"vectors.asm", line 281:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        LDP                #DP_EVA
"vectors.asm", line 290:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
                        SPLK        #0FFFFH,EVAIFRA
"vectors.asm", line 291:  AN IDENTIFIER IN THE EXPRESSION IS INVALID
The following symbols are undefined:
  EVAIFRA
  GPTCONA
  EVAIMRA
  T1PR
  MCRA
  MCRC
  PBDATDIR
  DP_PF2
  DP_EVA
  SCSR1
  IFR
  IMR
  PFDATDIR
  WDCR
  T1CON
  PIVR
  T1CNT
  BIT8
34 Errors,  No Warnings
Errors in source - Assembler Aborted
Build Complete,
  34 Errors, 0 Warnings, 0 Remarks.
求指导,不太懂
