3920|2
arduino mega256 1602 扩展库 [复制链接]
1.myLCD1602.cpp
//#include "WProgram.h"
#include "Arduino.h"
#include
#define uchar unsigned char
uchar RS = 22;
uchar RW = 23;
uchar E =24;
uchar D0 = 25;
uchar D1 = 26;
uchar D2 = 27;
uchar D3 = 28;
uchar D4 = 29;
uchar D5 = 30;
uchar D6 = 31;
uchar D7 = 32;
myLCD::myLCD()
void  myLCD::lcdWriteCmd(uchar cmd)
  uchar i;
  digitalWrite(RS,LOW);
  digitalWrite(RW,LOW);
  for(i=0;i<8;i++)
    digitalWrite(25+i,cmd & 0x1);
    cmd >>=1;
  digitalWrite(E,LOW);
  delayMicroseconds(1);
  digitalWrite(E,HIGH);
void myLCD::lcdWriteData(uchar data)
  uchar i;
  digitalWrite(RS,HIGH);
  for(i=0;i<8;i++)
    digitalWrite(25+i,data & 0x1);
    data>>=1;
void myLCD::lcdInit()
        char i;
  //set use pin output
  for(i=0;i<11;i++)
    pinMode(22+i,OUTPUT);
  delay(100);
  lcdWriteCmd(0x38);
  delay(64);
  lcdWriteCmd(0x38);
  delay(50);
  lcdWriteCmd(0x38);
  delay(20);
  lcdWriteCmd(0x06);
  delay(20);
  lcdWriteCmd(0x0e);
  delay(20);
  lcdWriteCmd(0x01);
  delay(100);
  lcdWriteCmd(0x80);
  delay(20);
//x==0 or 1, 0<=y<16
void myLCD::lcdSetXY(uchar x,uchar y)
        lcdWriteCmd(0x0c);
  delay(10);
  if(x==0)
                  lcdWriteCmd(0x80+y);
  else if(x==1)
                  lcdWriteCmd(0xc0+y);
  else
  delay(10);
void myLCD::lcdClear()
                lcdWriteCmd(0x01);
          delay(10);
void myLCD::lcdWrite(unsigned char *data,unsigned char size)
        uchar i;
        for(i=0;i         {
                lcdWriteData(*data++);
2.myLCD1602.h
#ifndef myLCD1602
#define myLCD1602
class myLCD{
        public:
        myLCD();
        void lcdInit();
        void lcdSetXY(uchar x,uchar y);
        void lcdWrite(uchar *data,uchar size);
        private:
        void  lcdWriteCmd(uchar cmd);
        void  lcdWriteData(uchar data);
#endif
3.keywords.txt
myLCD        KEYWORD1
lcdInit        KEYWORD2
lcdSetXY KEYWORD2
lcdWrite        KEYWORD2
4.testlib.ino
#include
myLCD mylcd1;
char ledpin=38;
void setup()
  mylcd1.lcdInit();
void loop()
  unsigned char test[]={'A','r','d','u','i','n','o'};
  unsigned char test1[]={'e','r','a','i','n','_','3','0'};
  mylcd1.lcdSetXY(0,4);
  mylcd1.lcdWrite(test,7);
  mylcd1.lcdSetXY(1,4);
  mylcd1.lcdWrite(test1,8);
  pinMode(ledpin,OUTPUT);
  while(1)
    digitalWrite(ledpin,LOW);
    delay(500);
    digitalWrite(ledpin,HIGH);
    delay(500);
  详情 回复 发表于 2014-5-10 08:54
1071
感谢楼主分享
开源项目 更多>>
