9893|2
stm32 can好几天都调试不通,请各位高手指点一下,谢谢 [复制链接]
测试环境:stm32+ISO1050 接stm32+ISO1050,相当于连个stm32对接
stm32 can好几天都调试不通,更奇怪,打印一些错误信息,竟然显示没有错误,各位高手指点,谢谢
当把两个stm32之间can线缆接上时,检查错误打印信息是没有错误,消息一直pengding状态,但是又没有显示错误
TxMessage.StdId =0x00 0x01
TxMessage.ExtId =0x12 0x34
TxMessage.RTR =0x00
TxMessage.IDE =0x00
TxMessage.DLC =0x02
TxMessage.Data =0x01 0x02
Mail box is ok
message send pending
CAN_FLAG_BOF = RESET
CAN_FLAG_EWG = RESET
CAN_FLAG_EPV = RESET
当把两个stm32之间can线缆断开时,检查错误打印信息是有错误的,消息一直pengding状态
TxMessage.RTR =0x00
TxMessage.IDE =0x00
TxMessage.DLC =0x02
Mail box is ok
CAN_FLAG_EWG = SET
CAN_FLAG_EPV = SET
CAN_FLAG_EWG = SET
CAN_FLAG_EPV = SET
CAN_FLAG_EWG = SET
CAN_FLAG_EPV = SET
代码如下:
TransmitMailbox = CAN_Transmit(CAN1,&TxMessage);
    if(CAN_NO_MB == TransmitMailbox)
        //发送失败,没有空邮箱
        PUT("Mail box is nok\r\n");
        return 0;
    else
        PUT("Mail box is ok\r\n");
        CAN_msg_num[TransmitMailbox] = 1;
    do
        message_tx_status = CAN_TransmitStatus(CAN1, TransmitMailbox);
         if(message_tx_status == CANTXOK)
             PUT("message send ok\r\n");
         else if(message_tx_status == CANTXPENDING)
            PUT("message send pending\r\n");
         else if(message_tx_status == CANTXFAILED)
            PUT("message send failed\r\n");
         delay_GSM(10000);
         retry_time++;
         Status_sign = CAN_GetFlagStatus(CAN1,CAN_FLAG_BOF);
         if(Status_sign == SET)
             PUT("CAN_FLAG_BOF = SET \r\n");
             CAN1->MCR|=1;
            CAN1->MCR&=0xfffffffe;
         else
             PUT("CAN_FLAG_BOF = RESET \r\n");
         Status_sign = CAN_GetFlagStatus(CAN1,CAN_FLAG_EWG);
             PUT("CAN_FLAG_EWG = SET \r\n");
         else
             PUT("CAN_FLAG_EWG = RESET \r\n");
         Status_sign = CAN_GetFlagStatus(CAN1,CAN_FLAG_EPV);
             PUT("CAN_FLAG_EPV = SET \r\n");
         else
             PUT("CAN_FLAG_EPV = RESET \r\n");
此帖出自stm32/stm8论坛
CAN驱动芯片  有一个引脚 需接1K电阻   详情 回复 发表于 2014-8-7 08:45
     /* CAN FIFO0 message pending interrupt enable */
    //CAN_ITConfig(CAN1,CAN_IT_FMP0, ENABLE);
     /* disable interrupt handling */
   // CAN_ITConfig(CAN1,CAN_IT_FMP0, DISABLE);
        //发送失败,没有空邮箱
        return 0;
    else
    do
         delay_GSM(10000);
         retry_time++;
             CAN1->MCR|=1;
         else
         else
         else
    }while((message_tx_status != CANTXOK)&&(retry_time <3));
此帖出自stm32/stm8论坛
此帖出自stm32/stm8论坛
