3732|0
MSP430F5438A的spi例程 [复制链接]
TI公司的一个关于MSP430F5438A的spi例子。
下面是msater的程序。
#define SPICLK                          500000
unsigned char transmitData = 0x00, receiveData = 0x00;
unsigned short returnValue = 0x00;
void main (void)
    //Stop watchdog timer
    WDT_hold(__MSP430_BASEADDRESS_WDT_A__);
    //Set P1.1 for slave reset
    GPIO_setOutputHighOnPin(
        __MSP430_BASEADDRESS_PORT1_R__,
        GPIO_PORT_P1,
        GPIO_PIN1
    //Set P1.0 to output direction
    GPIO_setAsOutputPin(__MSP430_BASEADDRESS_PORT1_R__,
        GPIO_PORT_P1,
        GPIO_PIN0
    //P3.5,4,0 option select
    GPIO_setAsPeripheralModuleFunctionInputPin(__MSP430_BASEADDRESS_PORT3_R__,
        GPIO_PORT_P3,
        GPIO_PIN5 + GPIO_PIN4 + GPIO_PIN0
    //Initialize Master
    returnValue = SPI_masterInit(__MSP430_BASEADDRESS_USCI_A0__,
        SPI_CLOCKSOURCE_SMCLK,
        UCS_getSMCLK(__MSP430_BASEADDRESS_UCS__),
        SPICLK,
        SPI_MSB_FIRST,
        SPI_PHASE_DATA_CHANGED_ONFIRST_CAPTURED_ON_NEXT,
        SPI_CLOCKPOLARITY_INACTIVITY_HIGH
    if (STATUS_FAIL == returnValue){
        return;
    //Enable SPI module
    SPI_enable(__MSP430_BASEADDRESS_USCI_A0__);
    //Enable Receive interrupt
    SPI_enableInterrupt(__MSP430_BASEADDRESS_USCI_A0__, SPI_RECEIVE_INTERRUPT);
    //Now with SPI signals initialized, reset slave
    GPIO_setOutputLowOnPin(
        GPIO_PORT_P1,
        GPIO_PIN1
    //LED On
        GPIO_PORT_P1,
        GPIO_PIN0
    //Wait for slave to initialize
    __delay_cycles(100);
    //Initialize data values
    transmitData = 0x00;
    //USCI_A0 TX buffer ready?
    while (!SPI_getInterruptStatus(__MSP430_BASEADDRESS_USCI_A0__,
               SPI_TRANSMIT_INTERRUPT)) ;
    //Transmit Data to slave
    SPI_transmitData(__MSP430_BASEADDRESS_USCI_A0__, transmitData);
    //CPU off, enable interrupts  CPU停止,启用中断LPM0
    __bis_SR_register(LPM0_bits + GIE);
//This is the USCI_B0 interrupt vector service routine
#pragma vector=USCI_A0_VECTOR
__interrupt void USCI_A0_ISR (void)
    switch (__even_in_range(UCA0IV,4)){
        //Vector 2 - RXIFG
        case 2:
            //USCI_A0 TX buffer ready?  USCI_A0 TX 寄存器准备好了吗?
            receiveData = SPI_receiveData(__MSP430_BASEADDRESS_USCI_A0__);
            //Increment
            transmitData++;
            //Send next value
            transmitData
            //Delay between transmissions for slave to process information
            __delay_cycles(40);
            break;
        default: break;
还有一个slaver的程序。两个我分别使用两块MSP430F5438A的板子,接口就是两块板子的P3.0,P3.4,P3.5分别相连,然后主机的P1.1连接从机的RST(我的板子的RST是在JTAG里的一个脚),连接的就这些,还有就是我给主机供电,然后单步运行master的程序,能看到从机的led1灯亮但是很暗,这个是正常现象吗?能证明程序或是我连接使用的正确吗?不正确的话,那应该怎么修改呢?正确的现象又是什么呢?
