6046|5
888
提问+目前TI最高端安防音视频芯片DM8168,有多少人在用呢? [复制链接]
DM8168这款芯片适合做视频多通道 + 算法的开发。开发平台有EZSDK/DVRRDK等
大家有用吗,一起交流一下。
我用的是DVRRDK中的demo_link_api来进行2路高清采集和2路解码播放。
Compare Parts
Status
ACTIVE
ACTIVE
ACTIVE
Video Security
Thin Client
Video Conferencing
Video Phones
Video Security
Thin Client
Video Conferncing
Video Phones
Video Surveillance
Operating Systems
Linux
Android
DSP/BIOS
Linux
DSP/BIOS
Linux
DSP/BIOS
DSP
1 C674x
1 C674x
1 C674x
DSP Instruction Type
Fixed and Floating Point
DSP MHz (Max.)
750
DSP Peak MMACS
12000
6000
6000
ARM CPU
1 ARM Cortex-A8
1 ARM Cortex-A8
1 ARM Cortex-A8
ARM MHz (Max.)
1200
ARM MIPS (Max.)
2400
2000
2000
Graphics Acceleration
1 3D
1 3D
Video Acceleration
3 HDVICPs
1 HDVICP
1 HDVICP
Video Capability
Decode
Encode
Multi-Channel
Transcode
Multi-format
Analytics
Image Enhance
Deinterlacing
Scaling
Decode
Encode
Multi-Channel
Transcode
Multi-format
Analytics
Image Enhance
Deinterlacing
Scaling
Decode
Encode
Multi-Channel
Transcode
Multi-format
Analytics
Image Enhance
Deinterlacing
Scaling
TI Video Codecs
H.264 BP/MP/HP
MPEG-4
MPEG-2
JPEG/MJPEG
H.264 BP/MP/HP
MPEG-4
MPEG-2
JPEG/MJPEG
H.264 BP/MP/HP
MPEG-4
MPEG-2
JPEG/MJPEG
Video Resolution/Frame Rate
1080p
60 FPS or less
1080p
60 FPS or less
1080p
60 FPS or less
TI Audio Codecs
AAC-LC/HE
G.711
MP3
AAC-LC/HE
G.711
MP3
AAC-LC/HE
G.711
MP3
On-Chip L1 Cache
64 KB (ARM Cortex-A8)
64 KB (DSP)
64 KB (DSP)
64 KB (DSP)
On-Chip L2 Cache
256 KB (ARM Cortex-A8)
256 KB (DSP)
512 KB (ARM)
256 KB (DSP)
256 KB (ARM)
256 KB (DSP)
Other On-Chip Memory
512 KB
128 KB
128 KB
General Purpose Memory
1 16-bit GPMC
NAND flash
NOR Flash
Pseudo-SRAM
SRAM
1 16-bit GPMC
LPDDR
NAND flash
NOR Flash
Pseudo-SRAM
SRAM
1 16-bit GPMC
LPDDR
NAND flash
NOR Flash
Pseudo-SRAM
SRAM
DRAM
2 32-bit (DDR2-800
DDR3-1600)
2 32-bit (DDR2-800
DDR3-800
LPDDR-400)
2 32-bit (DDR2-800
DDR3-800
LPDDR-400)
USB
EMAC
2x 10/100/1000
10/100/1000
10/100/1000
PCI/PCIe
1 2-lane
PCIe
PCIe
SATA
MMC/SD
1 SD/SDIO
UART (SCI)
I2C
McBSP
McASP
SPI
打算用8168做ISP算法,是用什么开发平台合适呢? EZSDK还是DVRRDK?  详情 回复 发表于 2015-8-22 22:17
个人签名邮箱:ternence.hsu@foxmail.com
900
推荐
没用过,不过感兴趣,关注下,希望高手过来分享经验
个人签名别打我! 我说。
283
这个现在比较火,还有dm8127 dm385也可以考虑一下
你好,我打算用8168开发视频图像处理系统 请教一些问题好吗
你好; 建议用DVRRDK开发,目前做dm8168开发的,非常大一部分人是在RDK上面开发,这样你能获取到更多的开发资源,能更好的开发ISP  详情 回复 发表于 2015-8-25 09:43
888
你好;
