| The name of the current build configuration, for example Debug or Release. |
$CUR_DIR$ | Current directory |
$CUR_LINE$ | Current line |
$DATE$ | Today’s date |
$EW_DIR$ | Top directory of IAR Embedded Workbench, for example c:\program files\iar systems\embedded workbench 6.n |
$EXE_DIR$ | Directory for executable output |
$FILE_BNAME$ | Filename without extension |
$FILE_BPATH$ | Full path without extension |
$FILE_DIR$ | Directory of active file, no filename |
$FILE_FNAME$ | Filename of active file without path |
$FILE_PATH$ | Full path of active file (in Editor, Project, or Message window) |
$LIST_DIR$ | Directory for list output |
$OBJ_DIR$ | Directory for object output |
$PROJ_DIR$ | Project directory |
$PROJ_FNAME$ | Project filename without path |
$PROJ_PATH$ | Full path of project file |
$TARGET_DIR$ | Directory of primary output file |
$TARGET_BNAME$ | Filename without path of primary output file and without extension |
$TARGET_BPATH$ | Full path of primary output file without extension |
$TARGET_FNAME$ | Filename without path of primary output file |
$TARGET_PATH$ | Full path of primary output file |
$TOOLKIT_DIR$ | Directory of the active product, for example c:\program files\iar systems\embedded workbench 6.n\arm |
$USER_NAME$ | Your host login name |
| The environment variable ENVVAR. Any name within $_ and _$ will be expanded to that system environment variable. |
