2054|1
110
富士通FRAM心得提交 [复制链接]
富士通FRAM与Arduino Uno
富士通FRAM为MB85RC128, 选用Arduino Uno作为I2C master.
MB85RC128管脚8 接3.3v 管脚4接地 管脚6接I2C SCL  管脚5接I2C SDA 管脚7为 写保护, 接地
1. 读取MB85RC128 I2C地址源程序, 地址为0x50
#include
void setup()
Wire.begin();
Serial.begin(9600);
Serial.println("\nI2C Scanner");
void loop()
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknow error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
else
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
2. 往MB85RC128 写数据并读取出来
#include //I2C library
  void i2c_eeprom_write_byte( int deviceaddress, unsigned int eeaddress, byte data ) {
    int rdata = data;
    Wire.beginTransmission(deviceaddress);
    Wire.write((int)(eeaddress >> 8)); // MSB
    Wire.write((int)(eeaddress & 0xFF)); // LSB
    Wire.write(rdata);
  // WARNING: address is a page address, 6-bit end will wrap around
  // also, data can be maximum of about 30 bytes, because the Wire library has a buffer of 32 bytes
  void i2c_eeprom_write_page( int deviceaddress, unsigned int eeaddresspage, byte* data, byte length ) {
    Wire.write((int)(eeaddresspage >> 8)); // MSB
    Wire.write((int)(eeaddresspage & 0xFF)); // LSB
    byte c;
    for ( c = 0; c < length; c++)
      Wire.write(data[c]);
  byte i2c_eeprom_read_byte( int deviceaddress, unsigned int eeaddress ) {
    byte rdata = 0xFF;
    Wire.write((int)(eeaddress & 0xFF)); // LSBWire.read
    Wire.requestFrom(deviceaddress,1);
    if (Wire.available()) rdata = Wire.read();
    return rdata;
  // maybe let's not read more than 30 or 32 bytes at a time!
  void i2c_eeprom_read_buffer( int deviceaddress, unsigned int eeaddress, byte *buffer, int length ) {
    Wire.requestFrom(deviceaddress,length);
    int c = 0;
    for ( c = 0; c < length; c++ )
      if (Wire.available()) buffer[c] = Wire.read();
  void setup()
    char somedata[] = "data from the fujitsu FRAM"; // data to write
    Wire.begin(); // initialise the connection
    Serial.begin(9600);
    i2c_eeprom_write_page(0x50, 0, (byte *)somedata, sizeof(somedata)); // write to FRAM
    delay(10); //add a small delay
    Serial.println("Memory FRAM written");
  void loop()
    int addr=0; //first address
    byte b = i2c_eeprom_read_byte(0x50, 0); // access the first address from the memory
    while (b!=0)
      Serial.print((char)b); //print content to serial port
      addr++; //increase address
      b = i2c_eeprom_read_byte(0x50, addr); //access an address from the memory
    Serial.println(" ");
    delay(2000);
I2C地址
I2C地址
FRAM 数据
FRAM 数据
Sur
赞一个,期待更多的分享  详情 回复 发表于 2014-1-6 09:15
赞赏
查看全部赞赏
1531
49
赞一个,期待更多的分享
个人签名NXP新年新气象大家一起嗨起来 + 恩智浦KW41Z有奖创意征集令高能来袭 +https://www.eeworld.com.cn/huodong/201611_NXPKW41ZActivity1/index.html
