2233|0
求助!VHDL 实现简易自动售货机 [复制链接]
要用VHDL实现简易的自动售货机
仿真时发现信号 MONEY 是未知的。刚学VHDL 很多都不会,花了很多时间最后能编译了,但还是有问题。求好心人抽空看下,谢谢了
程序如下:
library ieee;
use ieee.std_logic_1164.all ;
entity vending_machine is
        Port(
                        x,y,z,clk: in std_logic;
                        test: out integer range 0 to 100;
                        water,change: out std_logic);
end entity;
architecture design of vending_machine is
        type state_name is (waiting, A,B,C,SET);
        signal current_state, next_state: state_name;
        signal money : integer range 0 to 200:=0;
        begin
        process(clk)
        begin
        if clk='1' and clk'event then
        current_state<=next_state;
        end if;
        end process;
process(x,y,z)
variable temp: integer range 0 to 100:=0;
begin
if x ='1' then
money <= money+25;
elsif y ='1' then
money <= money+10;
elsif z ='1' then
money <= money+5;
ELSE money<=money;
end if ;
end process;
        process(x,y,z,current_state)
        begin
        case current_state is
when waiting =>
                if x ='1' then
                next_state <=A;
                elsif y ='1' then
                next_state <=B;
                elsif z ='1'then
                next_state <=C;
           else if money>75 then
                next_state<=SET;
                else next_state<=waiting;
                end if;
                end if;
when A=>
                when B=>
                when C=>
        when others=>
                end case;
end process;
process(current_state)
variable temp: integer range 0 to 100:=1;
                begin
                        when waiting =>
                        water<='0';
                        change<='0';
                        test<=money;
                        when A=>
                        water<='0';
                        change<='0';
                        test<=1;
                        when B=>
                        water<='0';
                        change<='0';
                        test<=2;
                        when C=>
                        water<='0';
                        change<='0';
                        test<=3;
                        when others=>
                        water<='1';
                        change<='1';
                        test<=money;
                        end case;
                        end process;
                        end design;
此帖出自FPGA/CPLD论坛
