2292|0
跟您一起做实验——ADUC系列的调试报告 [复制链接]
ADuC8XX UART Emulation
Many
customers have puzzles about the application of the ADuC8XX UART Emulation. This
document introduces the steps about how to realize it. Using UART Emulation can
save cost and make emulation easy but the function of MCU is limited. For
example, UART used to communicate with PC and Timer 1 can not be used in the
code.
32acbeef-7720-426c-823a-b463da7fed8a.pdf (252.86 KB, 下载次数: 14)
8c1d79d9-6f5f-48da-8866-7fa4fe81af35.pdf (587.75 KB, 下载次数: 14)
7b93d528-57a0-4c14-82f8-68ed550a57ff.pdf (276.25 KB, 下载次数: 7)
5d0501a9-0de7-4e48-83f6-f172ad688e5a.pdf (392.58 KB, 下载次数: 6)
4f4ce8d1-a961-4b22-977a-744d4ac24397.pdf (486.62 KB, 下载次数: 8)
