2807|1
请教高手:做51格力空调遥控器,解了码后不知为何空调没反应,附程序如下。 [复制链接]
#include
#define uchar unsigned char
#define uint unsigned int
sbit   output = P1^0;
sbit KEY1=P3^0;
sbit KEY2=P3^1;
sbit KEY3=P3^2;
sbit KEY4=P3^3;
static bit OP;        //红外发射管的亮灭
static unsigned int count;       //延时计数器
static unsigned int endcount; //终止延时计数
static unsigned char flag;      //红外发送标志
void SendIRdata(char p_irdata1,char p_irdata2,char p_irdata3,char p_irdata4,char p_irdata5);
void delay();
uchar KEY();
void Delay(uint del)
        uint i,j;
        for(i=0; i         for(j=0; j<1827; j++)
void main(void)
        uchar t;
    count = 0;
    flag = 0;
    OP = 0;
    output = 0;
    EA = 1; //允许CPU中断
    TMOD = 0x11; //设定时器0和1为16位模式1
    ET0 = 1; //定时器0中断允许
    TH0 = 0xFF;
    TL0 = 0xE8; //设定时值0为38K 也就是每隔26us中断一次 ,晶振11.0592M
    TR0 = 1;//开始计数
    do{
                t=KEY();
                                switch(t)
                                   case 0:
                                        break;
                                case 1:
                                        SendIRdata(25,2,224,80,4);         //                1900e0514
                                        break;
                                case 2:
                                        SendIRdata(17,0,160,80,4);                 //
                                        break;
                                case 3:
                                        SendIRdata(25,1,224,80,4);         //
                                        break;
                                case 4:
                                        break;
    }while(1);
//定时器0中断处理
void timeint(void) interrupt 1
    TH0=0xFF;
    TL0=0xE8; //设定时值为38K 也就是每隔26us中断一次
    count++;
    if (flag==1)
        OP=~OP;
    else
        OP = 0;
    output = OP;
    int i;
    char irdata;
    //发送9ms的起始码
    endcount=250;
    flag=1;
    count=0;
    do{}while(count
    //发送4.5ms的结果码
    endcount=117;
    flag=0;
    count=0;
    do{}while(count
    //发送十六位地址的前八位
    irdata=p_irdata1;
    for(i=0;i<8;i++)
        //先发送0.56ms的38KHZ红外波(即编码中0.56ms的高电平)
        endcount=12;
        flag=1;
        count=0;
        do{}while(count
        //停止发送红外信号(即编码中的高电平)
        if(irdata-(irdata/2)*2)  //判断二进制数个位为1还是0
            endcount=45;  //1为宽的低电平
        else
            endcount=15;   //0为窄的低电平
        flag=0;
        count=0;
        do{}while(count
        irdata=irdata>>1;
    //发送十六位地址的后八位
    irdata=p_irdata2;
    for(i=0;i<8;i++)
        endcount=12;
        flag=1;
        count=0;
        do{}while(count
            endcount=45;
        else
            endcount=15;
        flag=0;
        count=0;
        do{}while(count
        irdata=irdata>>1;
    //发送八位数据
    irdata=p_irdata3;
    for(i=0;i<8;i++)
        endcount=12;
        flag=1;
        count=0;
        do{}while(count
            endcount=45;
        else
            endcount=15;
        flag=0;
        count=0;
        do{}while(count
        irdata=irdata>>1;
    //发送八位数据2
    irdata=p_irdata4;
    for(i=0;i<8;i++)
        endcount=12;
        flag=1;
        count=0;
        do{}while(count
            endcount=45;
        else
            endcount=15;
        flag=0;
        count=0;
        do{}while(count
        irdata=irdata>>1;
        //发送35位数据中最后三位数据
    irdata=p_irdata5;
        irdata=irdata>>1;  //因为从低位开始发
    for(i=0;i<3;i++)
        endcount=12;
        flag=1;
        count=0;
        do{}while(count
            endcount=45;
        else
            endcount=15;
        flag=0;
        count=0;
        do{}while(count
        irdata=irdata>>1;
    endcount=12;
    flag=1;
    count=0;
    do{}while(count
    flag=0;
void delay()
    int i,j;
    for(i = 0; i < 400; i++){
        for(j = 0; j < 200; j++){
uchar KEY()
        if(KEY1 == 0 || KEY2 == 0 || KEY3 == 0 || KEY4 == 0)
                Delay(2);
                if(KEY1 == 0)
                        while(1)
                                if(KEY1 == 1)
                                        Delay(2);
                                        if(KEY1 == 1)
                                                break;
                        return 1;
                if(KEY2 == 0)
                        while(1)
                                if(KEY2 == 1)
                                        Delay(2);
                                        if(KEY2 == 1)
                                                break;
                        return 2;
                if(KEY3 == 0)
                        while(1)
                                if(KEY3 == 1)
                                        Delay(2);
                                        if(KEY3 == 1)
                                                break;
                        return 3;
                if(KEY4 == 0)
                        while(1)
                                if(KEY4 == 1)
                                        Delay(2);
                                        if(KEY4 == 1)
                                                break;
                        return 4;
        return 0;
此帖出自51单片机论坛
额,代码好长,不过你感觉有人会看吗  详情 回复 发表于 2013-10-27 23:27
63
额,代码好长,不过你感觉有人会看吗
此帖出自51单片机论坛
