2985|2
468
uboot 执行顺序 [复制链接]
init_fnc_t *init_sequence[] = {
        cpu_init,                /* basic cpu dependent setup */
#if defined(CONFIG_SKIP_RELOCATE_UBOOT)
        reloc_init,                /* Set the relocation done flag, must
                                   do this AFTER cpu_init(), but as soon
                                   as possible */
#endif
        board_init,                /* basic board dependent setup */
        interrupt_init,                /* set up exceptions */
        env_init,                /* initialize environment */
        init_baudrate,                /* initialze baudrate settings */
        serial_init,                /* serial communications setup */
        console_init_f,                /* stage 1 init of console */
        display_banner,                /* say that we are here */
#if defined(CONFIG_DISPLAY_CPUINFO)
        print_cpuinfo,                /* display cpu info (and speed) */
#endif
#if defined(CONFIG_DISPLAY_BOARDINFO)
        checkboard,                /* display board info */
#endif
#if defined(CONFIG_HARD_I2C) || defined(CONFIG_SOFT_I2C)
        init_func_i2c,
#endif
        dram_init,                /* configure available RAM banks */
        display_dram_config,
        NULL,
在void start_armboot (void)
monitor_flash_len = _bss_start - _armboot_start;
        for (init_fnc_ptr = init_sequence; *init_fnc_ptr; ++init_fnc_ptr) {
                if ((*init_fnc_ptr)() != 0) {
                        hang ();
468
  1. #ifndef _U_BOOT_H_
  2. #define _U_BOOT_H_        1
  3. typedef struct bd_info {
  4.     int                        bi_baudrate;        /* serial console baudrate */
  5.     unsigned long        bi_ip_addr;        /* IP Address */
  6.     unsigned char        bi_enetaddr[6]; /* Ethernet adress */
  7.     struct environment_s               *bi_env;
  8.     ulong                bi_arch_number;        /* unique id for this board */
  9.     ulong                bi_boot_params;        /* where this board expects params */
  10.     struct                                /* RAM configuration */
  11.     {
  12.         ulong start;
  13.         ulong size;
  14.     }                        bi_dram[CONFIG_NR_DRAM_BANKS];
  15. #ifdef CONFIG_HAS_ETH1
  16.     /* second onboard ethernet port */
  17.     unsigned char   bi_enet1addr[6];
  18. #endif
  19. } bd_t;
  20. #define bi_env_data bi_env->data
  21. #define bi_env_crc  bi_env->crc
  22. #endif        /* _U_BOOT_H_ */
复制代码
468
我晕在
下面增加一些函数 ,运行函数后uboot就死机了,咋回事?
                                   as possible */
#endif
#endif
#endif
        init_func_i2c,
#endif
        NULL,
