2905|1
854
.NET Compact Framework 3.5 和OS Dependencies for .NET Compact Framework 3.5区别 [复制链接]
这两个组件有啥关系,我记得以前同时选择会有问题,现在再重新测试一下。
个人签名如果对linux,Android,wince 等嵌入式底层有兴趣的,请加这个QQ群吧,群号:27100460
854
微软MSDN解释
Catalog itemSysgen variableDescription
SYSGEN_DOTNETV35_SUPPORT
Adds all the necessary files to your OS design, which are OS dependencies, to enable the .NET Compact Framework to run on a device that has a display screen. However, these files do not include the .NET Compact Framework.
OS Dependencies for .NET Compact Framework 3.5 - Headless
SYSGEN_DOTNETV35_SUPPORT_HEADLESS
Adds all the necessary files to your OS design, which are OS dependencies, to enable the .NET Compact Framework to run on a device that has no display screen. However, these files do not include the .NET Compact Framework.
SYSGEN_DOTNETV35
Adds the .NET Compact Framework 3.5 to your OS design for a device that has a display screen.
真是不知道这个微软是啥意思了。这个.......................However, these files do not include the .NET Compact Framework.
