2724|1
474
LM4F120的PWM [复制链接]
= =..做了做PWM的实验..翻阅StellarisWare的文档直接奔着Chapter 21 PWM那一章去了,写好代码上电,,没反应,,,调试,,发现进入了系统错误中断...
搞了半天才知道原来LM4F120没有PWM模块,还是得用定时器...晕..
  ROM_SysCtlClockSet(SYSCTL_SYSDIV_2_5 | SYSCTL_USE_PLL | SYSCTL_XTAL_16MHZ |           //80mhz
                       SYSCTL_OSC_MAIN);
  SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER0);
  SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
  GPIOPinConfigure(GPIO_PF1_T0CCP1);
  GPIOPinTypeTimer(GPIO_PORTF_BASE, GPIO_PIN_1);   //PF1
  TimerConfigure(TIMER0_BASE, TIMER_CFG_SPLIT_PAIR|TIMER_CFG_B_PWM);
  TimerLoadSet(TIMER0_BASE, TIMER_B, 50000);
  TimerMatchSet(TIMER0_BASE, TIMER_B, 40000); // PWM
  TimerEnable(TIMER0_BASE, TIMER_B);
一般就是这样启动的了.
但有一个疑问.
输出反相怎么设置?手册上说写TnPWML位设置输出正反相.可是在StellarisWare里面找不到相关的函数啊,,还得自己写寄存器..有大神找到么?
//***************************************************************************** // //! Controls the output level. //! //! \param ui32Base is the base address of the timer module. //! \param ui32Timer specifies the timer(s) to adjust; must be one of //! \b TIMER_A, \b TIMER_B, or \b TIMER_BOTH. //! \param bInvert specifies the output level. //! //! This function configures the PWM output level for the specified timer.  If //! the \e bInvert parameter is \b true, then the timer's output is made active //! low; otherwise, it is made active high. //! //! \return None. // //***************************************************************************** void TimerControlLevel(uint32_t ui32Base, uint32_t ui32Timer, bool bInvert) {     //     // Check the arguments.     //     ASSERT(_TimerBaseValid(ui32Base));     ASSERT((ui32Timer == TIMER_A) || (ui32Timer == TIMER_B) ||            (ui32Timer == TIMER_BOTH));     //     // Set the output levels as requested.     //     ui32Timer &= TIMER_CTL_TAPWML | TIMER_CTL_TBPWML;     HWREG(ui32Base + TIMER_O_CTL) = (bInvert ?                                      (HWREG(ui32Base + TIMER_O_CTL) |                                       ui32Timer) :                                      (HWREG(ui32Base + TIMER_O_CTL) &                                       ~(ui32Timer))); }  详情 回复 发表于 2013-9-3 16:11
//***************************************************************************** // //! Controls the output level. //! //! \\param ui32Base is the base address of the timer module. //! \\param ui  详情 回复 发表于 2013-9-3 16:11
1803
回复 楼主zgbkdlm 的帖子
//! \return None.
void
                                      ui32Timer) :
                                      ~(ui32Timer)));
