8883|6
348
F28335外部中断例子分享 [复制链接]
一个外部中断的例子,此例中使用了不可屏蔽中断,中断触发引脚GPIO16,触发方式边沿触发,供大家参考。主程序如下,工程见附件。
#include "DSP2833x_Device.h"     // Headerfile Include File
#include "DSP2833x_Examples.h"   // Examples Include File
#define   LED1 GpioDataRegs.GPBDAT.bit.GPIO60
#define   LED2 GpioDataRegs.GPBDAT.bit.GPIO61
#define   inpt GpioDataRegs.GPADAT.bit.GPIO16
interrupt void nmi_isr(void);
void configtestled(void);
void main(void)
   InitSysCtrl();
   DINT;
   InitPieCtrl();
   IER = 0x0000;
   IFR = 0x0000;
   InitPieVectTable();
   EALLOW;
   PieVectTable.XNMI = &nmi_isr;
   EDIS;
   EINT;                                       // Enable Global Interrupts
   configtestled();
// GPIO16 is input
   EALLOW;
   GpioCtrlRegs.GPAMUX2.bit.GPIO16 = 0;         // GPIO
   GpioCtrlRegs.GPADIR.bit.GPIO16 = 0;          // input
   GpioCtrlRegs.GPAQSEL2.bit.GPIO16 = 0;        // XNMI Synch to SYSCLKOUT only
   EDIS;
// GPIO16 is XNMI
   EALLOW;
   GpioIntRegs.GPIOXNMISEL.bit.GPIOSEL = 16;   // XNMI is GPIO16
   EDIS;
   EALLOW;
// Configure NMI
   XIntruptRegs.XNMICR.bit.POLARITY = 3;      // Rising & Falling edge interrupt
// Enable XNMI
   XIntruptRegs.XNMICR.bit.ENABLE = 1;        // Enable XNMI
   XIntruptRegs.XNMICR.bit.SELECT = 0;
   EDIS;
   LED1 = 1;
   LED2 = 1;
   DINT;
   for(;;)
LED1 = ~LED1;
if (inpt == 1)
LED2 = 0;
else
LED2 = 1;
EDIS;
   EALLOW;
   GpioCtrlRegs.GPBMUX2.bit.GPIO60 = 0; // GPIO60 = GPIO60
   GpioCtrlRegs.GPBDIR.bit.GPIO60 = 1;
   GpioCtrlRegs.GPBMUX2.bit.GPIO61 = 0; // GPIO61 = GPIO61
   GpioCtrlRegs.GPBDIR.bit.GPIO61 = 1;
   EDIS;
External Interrupt.zip
291.1 KB, 下载次数: 46
售价: 1 分芯积分  [记录]
有用,谢谢分享  详情 回复 发表于 2016-12-28 10:20
赞赏
查看全部赞赏
6066
92
裸片初长成(初级)
谢谢分享!
谢谢楼主分享
可以用!非常感谢楼主!帮了我大忙!!!
下载下来看看
谢谢分享
有用,谢谢分享
