5141|0
请教:ccs5.4 编译DSPf2812 始终不能下载的问题~ [复制链接]
我是DSP菜鸟,这几天学习DSP时吧编译环境从CCS3.3变成CCS5.4,同样的例程代码,同样的操作,有的代码可以下载通过并运行成功。有的就是不能下载,这几个目前遇到的是dsp 2812内部ADC,SPI等,像定时器,中断,按键,之类的正常下载,编译时有警告,界面是这样,请高手帮助下,问了很多人,就是解决不了。。中国源创立的开发板,三兄弟的XDS100V2仿真器。。
警告:
Description Resource Path Location Type
Build variable 'XDAIS_CG_ROOT' cannot be resolved. SPILED properties Problems
Invalid project path: Include path not found (\packages\ti\xdais). SPILED pathentry Path Entry Problem
还有这样的界面:
**** Build of configuration Debug for project SPILED ****
"C:\\ti\\ccsv5\\utils\\bin\\gmake" -k all
'Building file: D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_Adc.c'
'Invoking: C2000 Compiler'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -g --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --include_path="C:/tidcs/c28/DSP281x/v120/DSP281x_headers/include" --include_path="/packages/ti/xdais" --define="_DEBUG" --define="LARGE_MODEL" --quiet --display_error_number --diag_wrap=off --obj_directory="J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug" --preproc_with_compile --preproc_dependency="DSP28_Adc.pp"  "D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_Adc.c"
"C:\Users\LHW\AppData\Local\Temp\0573610", ERROR!   at EOF: [E1500]
         file access error:  failed to open
           "J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_Adc.obj"
           for writing
"C:\Users\LHW\AppData\Local\Temp\0573610", ERROR!  : [E1000] Failed to write
                                                             object file :
>> Compilation failure
gmake: *** [J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_Adc.obj] Error 1
'Building file: D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_CpuTimers.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -g --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --include_path="C:/tidcs/c28/DSP281x/v120/DSP281x_headers/include" --include_path="/packages/ti/xdais" --define="_DEBUG" --define="LARGE_MODEL" --quiet --display_error_number --diag_wrap=off --obj_directory="J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug" --preproc_with_compile --preproc_dependency="DSP28_CpuTimers.pp"  "D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_CpuTimers.c"
"C:\Users\LHW\AppData\Local\Temp\0376010", ERROR!   at EOF: [E1500]
           "J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_CpuTimers.obj"
           for writing
"C:\Users\LHW\AppData\Local\Temp\0376010", ERROR!  : [E1000] Failed to write
                                                             object file :
>> Compilation failure
gmake: *** [J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_CpuTimers.obj] Error 1
'Building file: D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_DefaultIsr.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -g --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --include_path="C:/tidcs/c28/DSP281x/v120/DSP281x_headers/include" --include_path="/packages/ti/xdais" --define="_DEBUG" --define="LARGE_MODEL" --quiet --display_error_number --diag_wrap=off --obj_directory="J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug" --preproc_with_compile --preproc_dependency="DSP28_DefaultIsr.pp"  "D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_DefaultIsr.c"
"C:\Users\LHW\AppData\Local\Temp\0444810", ERROR!   at EOF: [E1500]
           "J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_DefaultIsr.obj"
           for writing
"C:\Users\LHW\AppData\Local\Temp\0444810", ERROR!  : [E1000] Failed to write
                                                             object file :
>> Compilation failure
gmake: *** [J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_DefaultIsr.obj] Error 1
'Building file: D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_ECan.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -g --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --include_path="C:/tidcs/c28/DSP281x/v120/DSP281x_headers/include" --include_path="/packages/ti/xdais" --define="_DEBUG" --define="LARGE_MODEL" --quiet --display_error_number --diag_wrap=off --obj_directory="J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug" --preproc_with_compile --preproc_dependency="DSP28_ECan.pp"  "D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_ECan.c"
"C:\Users\LHW\AppData\Local\Temp\0063210", ERROR!   at EOF: [E1500]
           "J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_ECan.obj"
>> Compilation failure
           for writing
"C:\Users\LHW\AppData\Local\Temp\0063210", ERROR!  : [E1000] Failed to write
                                                             object file :
gmake: *** [J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_ECan.obj] Error 1
'Building file: D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_Ev.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -g --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --include_path="C:/tidcs/c28/DSP281x/v120/DSP281x_headers/include" --include_path="/packages/ti/xdais" --define="_DEBUG" --define="LARGE_MODEL" --quiet --display_error_number --diag_wrap=off --obj_directory="J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug" --preproc_with_compile --preproc_dependency="DSP28_Ev.pp"  "D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_Ev.c"
"C:\Users\LHW\AppData\Local\Temp\0446810", ERROR!   at EOF: [E1500]
           "J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_Ev.obj"
           for writing
"C:\Users\LHW\AppData\Local\Temp\0446810", ERROR!  : [E1000] Failed to write
                                                             object file :
>> Compilation failure
gmake: *** [J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_Ev.obj] Error 1
'Building file: D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_GlobalVariableDefs.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -g --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --include_path="C:/tidcs/c28/DSP281x/v120/DSP281x_headers/include" --include_path="/packages/ti/xdais" --define="_DEBUG" --define="LARGE_MODEL" --quiet --display_error_number --diag_wrap=off --obj_directory="J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug" --preproc_with_compile --preproc_dependency="DSP28_GlobalVariableDefs.pp"  "D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_GlobalVariableDefs.c"
"C:\Users\LHW\AppData\Local\Temp\0118010", ERROR!   at EOF: [E1500]
           "J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_GlobalVariableDefs.obj"
           for writing
"C:\Users\LHW\AppData\Local\Temp\0118010", ERROR!  : [E1000] Failed to write
                                                             object file :
>> Compilation failure
gmake: *** [J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_GlobalVariableDefs.obj] Error 1
'Building file: D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_Gpio.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -g --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --include_path="C:/tidcs/c28/DSP281x/v120/DSP281x_headers/include" --include_path="/packages/ti/xdais" --define="_DEBUG" --define="LARGE_MODEL" --quiet --display_error_number --diag_wrap=off --obj_directory="J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug" --preproc_with_compile --preproc_dependency="DSP28_Gpio.pp"  "D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_Gpio.c"
"C:\Users\LHW\AppData\Local\Temp\0451210", ERROR!   at EOF: [E1500]
           "J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_Gpio.obj"
           for writing
"C:\Users\LHW\AppData\Local\Temp\0451210", ERROR!  : [E1000] Failed to write
                                                             object file :
>> Compilation failure
gmake: *** [J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_Gpio.obj] Error 1
'Building file: D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_InitPeripherals.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -g --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --include_path="C:/tidcs/c28/DSP281x/v120/DSP281x_headers/include" --include_path="/packages/ti/xdais" --define="_DEBUG" --define="LARGE_MODEL" --quiet --display_error_number --diag_wrap=off --obj_directory="J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug" --preproc_with_compile --preproc_dependency="DSP28_InitPeripherals.pp"  "D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_InitPeripherals.c"
"C:\Users\LHW\AppData\Local\Temp\0458010", ERROR!   at EOF: [E1500]
           "J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_InitPeripherals.obj"
           for writing
"C:\Users\LHW\AppData\Local\Temp\0458010", ERROR!  : [E1000] Failed to write
                                                             object file :
>> Compilation failure
gmake: *** [J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_InitPeripherals.obj] Error 1
'Building file: D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_Mcbsp.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -g --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --include_path="C:/tidcs/c28/DSP281x/v120/DSP281x_headers/include" --include_path="/packages/ti/xdais" --define="_DEBUG" --define="LARGE_MODEL" --quiet --display_error_number --diag_wrap=off --obj_directory="J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug" --preproc_with_compile --preproc_dependency="DSP28_Mcbsp.pp"  "D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_Mcbsp.c"
"C:\Users\LHW\AppData\Local\Temp\0329210", ERROR!   at EOF: [E1500]
           "J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_Mcbsp.obj"
           for writing
"C:\Users\LHW\AppData\Local\Temp\0329210", ERROR!  : [E1000] Failed to write
                                                             object file :
>> Compilation failure
gmake: *** [J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_Mcbsp.obj] Error 1
'Building file: D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_PieCtrl.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -g --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --include_path="C:/tidcs/c28/DSP281x/v120/DSP281x_headers/include" --include_path="/packages/ti/xdais" --define="_DEBUG" --define="LARGE_MODEL" --quiet --display_error_number --diag_wrap=off --obj_directory="J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug" --preproc_with_compile --preproc_dependency="DSP28_PieCtrl.pp"  "D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_PieCtrl.c"
"C:\Users\LHW\AppData\Local\Temp\0352010", ERROR!   at EOF: [E1500]
           "J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_PieCtrl.obj"
           for writing
"C:\Users\LHW\AppData\Local\Temp\0352010", ERROR!  : [E1000] Failed to write
                                                             object file :
>> Compilation failure
gmake: *** [J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_PieCtrl.obj] Error 1
'Building file: D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_PieVect.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -g --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --include_path="C:/tidcs/c28/DSP281x/v120/DSP281x_headers/include" --include_path="/packages/ti/xdais" --define="_DEBUG" --define="LARGE_MODEL" --quiet --display_error_number --diag_wrap=off --obj_directory="J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug" --preproc_with_compile --preproc_dependency="DSP28_PieVect.pp"  "D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_PieVect.c"
"C:\Users\LHW\AppData\Local\Temp\0415610", ERROR!   at EOF: [E1500]
           "J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_PieVect.obj"
           for writing
"C:\Users\LHW\AppData\Local\Temp\0415610", ERROR!  : [E1000] Failed to write
                                                             object file :
>> Compilation failure
gmake: *** [J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_PieVect.obj] Error 1
'Building file: D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_Sci.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -g --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --include_path="C:/tidcs/c28/DSP281x/v120/DSP281x_headers/include" --include_path="/packages/ti/xdais" --define="_DEBUG" --define="LARGE_MODEL" --quiet --display_error_number --diag_wrap=off --obj_directory="J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug" --preproc_with_compile --preproc_dependency="DSP28_Sci.pp"  "D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_Sci.c"
"C:\Users\LHW\AppData\Local\Temp\0215210", ERROR!   at EOF: [E1500]
           "J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_Sci.obj"
           for writing
"C:\Users\LHW\AppData\Local\Temp\0215210", ERROR!  : [E1000] Failed to write
                                                             object file :
>> Compilation failure
gmake: *** [J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_Sci.obj] Error 1
'Building file: D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_Spi.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -g --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --include_path="C:/tidcs/c28/DSP281x/v120/DSP281x_headers/include" --include_path="/packages/ti/xdais" --define="_DEBUG" --define="LARGE_MODEL" --quiet --display_error_number --diag_wrap=off --obj_directory="J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug" --preproc_with_compile --preproc_dependency="DSP28_Spi.pp"  "D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_Spi.c"
"C:\Users\LHW\AppData\Local\Temp\0588810", ERROR!   at EOF: [E1500]
           "J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_Spi.obj"
           for writing
"C:\Users\LHW\AppData\Local\Temp\0588810", ERROR!  : [E1000] Failed to write
                                                             object file :
>> Compilation failure
gmake: *** [J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_Spi.obj] Error 1
'Building file: D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_SysCtrl.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -g --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --include_path="C:/tidcs/c28/DSP281x/v120/DSP281x_headers/include" --include_path="/packages/ti/xdais" --define="_DEBUG" --define="LARGE_MODEL" --quiet --display_error_number --diag_wrap=off --obj_directory="J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug" --preproc_with_compile --preproc_dependency="DSP28_SysCtrl.pp"  "D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_SysCtrl.c"
"C:\Users\LHW\AppData\Local\Temp\0434010", ERROR!   at EOF: [E1500]
           "J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_SysCtrl.obj"
           for writing
"C:\Users\LHW\AppData\Local\Temp\0434010", ERROR!  : [E1000] Failed to write
                                                             object file :
>> Compilation failure
gmake: *** [J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_SysCtrl.obj] Error 1
'Building file: D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_XIntrupt.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -g --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --include_path="C:/tidcs/c28/DSP281x/v120/DSP281x_headers/include" --include_path="/packages/ti/xdais" --define="_DEBUG" --define="LARGE_MODEL" --quiet --display_error_number --diag_wrap=off --obj_directory="J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug" --preproc_with_compile --preproc_dependency="DSP28_XIntrupt.pp"  "D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_XIntrupt.c"
"C:\Users\LHW\AppData\Local\Temp\0441210", ERROR!   at EOF: [E1500]
           "J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_XIntrupt.obj"
           for writing
"C:\Users\LHW\AppData\Local\Temp\0441210", ERROR!  : [E1000] Failed to write
                                                             object file :
>> Compilation failure
gmake: *** [J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_XIntrupt.obj] Error 1
'Building file: D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_Xintf.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -g --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --include_path="C:/tidcs/c28/DSP281x/v120/DSP281x_headers/include" --include_path="/packages/ti/xdais" --define="_DEBUG" --define="LARGE_MODEL" --quiet --display_error_number --diag_wrap=off --obj_directory="J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug" --preproc_with_compile --preproc_dependency="DSP28_Xintf.pp"  "D:/WorkSpace/DSP_2812/SourceCode04_SPILED/DSP28_Xintf.c"
"C:\Users\LHW\AppData\Local\Temp\0429610", ERROR!   at EOF: [E1500]
           "J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_Xintf.obj"
           for writing
"C:\Users\LHW\AppData\Local\Temp\0429610", ERROR!  : [E1000] Failed to write
                                                             object file :
>> Compilation failure
gmake: *** [J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/DSP28_Xintf.obj] Error 1
'Building file: D:/WorkSpace/DSP_2812/SourceCode04_SPILED/SPILED.c'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -g --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --include_path="C:/tidcs/c28/DSP281x/v120/DSP281x_headers/include" --include_path="/packages/ti/xdais" --define="_DEBUG" --define="LARGE_MODEL" --quiet --display_error_number --diag_wrap=off --obj_directory="J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug" --preproc_with_compile --preproc_dependency="SPILED.pp"  "D:/WorkSpace/DSP_2812/SourceCode04_SPILED/SPILED.c"
"D:/WorkSpace/DSP_2812/SourceCode04_SPILED/SPILED.c", line 25: warning #225-D: function declared implicitly
"C:\Users\LHW\AppData\Local\Temp\0160010", ERROR!   at EOF: [E1500]
           "J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/SPILED.obj" for
           writing
"C:\Users\LHW\AppData\Local\Temp\0160010", ERROR!  : [E1000] Failed to write
                                                             object file :
>> Compilation failure
gmake: *** [J:/DSP2812_PRO_SourceCode/SourceCode04_SPILED/Debug/SPILED.obj] Error 1
gmake: Target `all' not remade because of errors.
**** Build Finished ****
请问哪位高手遇到过这样的问题,能指点小弟下,谢谢各位~~
