2433|2
667
C2000 按键中断 抖动 [复制链接]
新手刚开始学c2000 launchpad,设置了S3-GPIO12的按键中断程序,不过开始运行时发现没有按键也会进入中断。而运行几秒钟后就会变好。请问这是什么问题,程序如下:
中断函数:
interrupt void S3_GetPressed_isr(void)
        S3_GetPressed_Flag=1-S3_GetPressed_Flag;
        PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
注意:以下程序 EALLOW/EDIS未写出,实际程序中没问题的。
gpio初始化:
        GpioCtrlRegs.GPAPUD.bit.GPIO12 = 0;
        GpioCtrlRegs.GPAMUX1.bit.GPIO12 = 0;
        GpioCtrlRegs.GPADIR.bit.GPIO12 = 0;
        GpioCtrlRegs.GPAQSEL1.bit.GPIO12 = 2;
        GpioCtrlRegs.GPACTRL.bit.QUALPRD1 = 0xff;
        GpioIntRegs.GPIOXINT1SEL.bit.GPIOSEL = 12;
连接中断函数:
PieVectTable.XINT1 = &S3_GetPressed_isr;
中断使能:
   XIntruptRegs.XINT1CR.bit.POLARITY = 1;
   XIntruptRegs.XINT1CR.bit.ENABLE = 1;
IER |= M_INT1;
PieCtrlRegs.PIEIER1.bit.INTx4 = 1;
请问问题在哪里?
加这些语句: // Disable CPU interrupts    DINT; // Initialize the PIE control registers to their default state. // The default state is all PIE interrupts disabled and flags // are cleared.    InitPieCtrl(); // Disable CPU interrupts and clear all CPU interrupt flags:    IER = 0x0000;    IFR = 0x0000; // Initialize the PIE vector table with pointers to the shell Interrupt    InitPieVectTable();  详情 回复 发表于 2013-8-14 20:37
2856
260
初始化时清除中断标志
348
加这些语句:
   DINT;
// are cleared.
   InitPieCtrl();
   IER = 0x0000;
   IFR = 0x0000;
   InitPieVectTable();
