3433|1
记录一下使用TM1668驱动 [复制链接]
单片机小白,记录一下使用TM1668驱动共阳极led贴片
#include	"config.h"
void Send_Data(unsigned char datas);
unsigned char getConmergeSegs(unsigned char data6,unsigned char data5,unsigned char data4,unsigned char data3,unsigned char data2,unsigned char data1,unsigned char bits);
void display_all(unsigned char data1,unsigned char data2,unsigned char data3,unsigned char data4,unsigned char data5,unsigned char data6);
//const unsigned char segs[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
const unsigned char segs[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
sbit DIO_1668 = P4^2 ;
sbit CLK_1668 = P3^4 ;
sbit STB_1668 = P3^5 ;
 * 程序名:开拓者NO.1
 * 描述  :tm1668.c
 * 输入  :无
 * 输出  :无
 void delay(int time)
	int i,j;
	 for(i=0;i<time;i++)
		for(j=0;j<1000;j++)
//==================   发送数据   =============================
	unsigned char i;
	STB_1668 = 0;
	delay(25);
   	for(i=0;i<8;i++)
		CLK_1668 = 0;   //PC8=0
		if((datas&0x01)==0x00)
					DIO_1668=0;
		else
					DIO_1668=1;
		delay(25);
		CLK_1668 = 1;  //PC8=1
		delay(25);
		datas=datas>>1;
	delay(25);
//============   共阴极显示转共阳极显示   ==========================
unsigned char getConmergeSegs(unsigned char data6,unsigned char data5,unsigned char data4,unsigned char data3,unsigned char data2,unsigned char data1,unsigned char bits) //bit=0..6
	unsigned char cal=0;
	unsigned char s6,s5,s4,s3,s2,s1;
	s6=segs[data6]>>bits;
	s5=segs[data5]>>bits;
 	s4=segs[data4]>>bits;
 	s3=segs[data3]>>bits;
 	s2=segs[data2]>>bits;
 	s1=segs[data1]>>bits;
	s6=(s6)&0x01;
  s5=(s5)&0x01;
  s4=(s4)&0x01;
  s3=(s3)&0x01;
  s2=(s2)&0x01;
  s1=(s1)&0x01;
	s6=s6<<5;
	s5=s5<<4;
  s4=s4<<3;
  s3=s3<<2;
  s2=s2<<1;
  cal=s6+s5+s4+s3+s2+s1;
  return cal;
//======================   显示函数   ==============================
	unsigned char dataa=0;
  unsigned char i=0;
  unsigned char m=0;
  STB_1668 = 0;
	Send_Data(0x03);
	STB_1668 = 1;
	delay(25);
	STB_1668 = 0;
	Send_Data(0x40);
	STB_1668 = 1;
	delay(25);
	STB_1668 = 0;
	Send_Data(0xC0);
	for(i=0;i<7;i++)
		if(m==0)
			dataa=getConmergeSegs(data6, data5, data4, data3, data2, data1,i);
			Send_Data(dataa);
		else
			Send_Data(0x0);
		Send_Data(0x01);
	STB_1668 = 1;
	delay(25);
	STB_1668 = 0;
	Send_Data(0x8f);
	STB_1668 = 1;
	delay(25);
extern void Delayms( uint32_t ms );
void tm1668_test(void)
	tm1668_init();
	//while(1)
		display_all(0x1,2,3,4);
		Delay_MS(20000);
		display_all(0x2,3,4,5);
		Delay_MS(20000);
	display_all(0x5,6,7,8);
  Delay_MS(20000);
	while(1){}
//=========================   TM1668初始化   =========================================
void tm1668_init(void)
  unsigned char i=0;
  unsigned char m=0;
  STB_1668 = 0;
	Send_Data(0x03);
	STB_1668 = 1;
	delay(25);
	STB_1668 = 0;
	Send_Data(0x40);
	STB_1668 = 1;
	delay(25);
	STB_1668 = 0;
	Send_Data(0xC0);
	for(i=0;i<7;i++)
		if(m==0)
			Send_Data(0xff);
		else
			Send_Data(0x0);
		Send_Data(0x0);
	STB_1668 = 1;
	delay(25);
	STB_1668 = 0;
	Send_Data(0x8f);
	STB_1668 = 1;
	delay(25);
//	display_all(i1,i1,i1,i1);
//	delay(1000);
此内容由EEWORLD论坛网友yleer3407原创,如需转载或用于商业用途需征得作者同意并注明出处
此帖出自51单片机论坛
感謝分享。   详情 回复 发表于 2019-9-20 21:48
96
感謝分享。
此帖出自51单片机论坛
