3249|0
275
(cyclone4)助学版_v120之数码管二[PWM可调显示0到100%] [复制链接]
(cyclone4)助学版_v120之数码管二:
操作系统:64位 Wins7编译软件:Quartus II 12.1
系统版:助学板V120
code 如下:
module seg(
                input clk,
                input[1:0] key,
                output reg[7:0] segment,
                output reg[2:0] wei,
                output reg PWM
reg clk_key;
reg[14:0] segment_scancnt;
reg[22:0] key_count;//2^23=8_388_608
reg[6:0] dis;//2^7=128
reg[12:0] key_cnt = 2400,cnt;//2^13=8192
parameter  PWM_cnt = 4800;//10kHz
parameter div_key = 5_280_000;//--->T=220ms
always @(posedge clk)//按键消抖时钟
begin
        if(key_count == div_key)
        begin
                key_count <= 0;
                clk_key <= ~clk_key;
        end
        else
                key_count <= key_count + 1'b1;
end
always @(posedge clk_key)//按键+/-
begin
        if(key == 2'b01)
        begin
                key_cnt = key_cnt + 6'd48;//百分之一可调
        end
        if(key == 2'b10)
        begin
                key_cnt = key_cnt - 6'd48;//百分之一可调
        end
        if(key_cnt > PWM_cnt)
        begin
                key_cnt = 0;
        end
        if(key_cnt == 13'd8192)
        begin
                key_cnt = PWM_cnt;
        end
end
always @(posedge clk)//分频10kHz-PWM波
begin
        if(cnt >= PWM_cnt)
        begin
                cnt = 0;
        end
        if(cnt < key_cnt)
                begin
                        PWM = 1;
                end
        else
                PWM = 0;
        cnt = cnt + 1'b1;
end
begin
        segment_scancnt <= segment_scancnt + 1'b1;
end
always @(segment_scancnt)//位选扫描
begin
        case(segment_scancnt[14:13])
        2'b00:
                wei <= 3'b011;
        2'b01:
                wei <= 3'b101;
        2'b10:
                wei <= 3'b110;
        default:wei <= 3'b111;
        endcase
end
always @(wei)//段选
begin
        case(wei)
        3'b011:
                segment <= display(key_cnt/48/100);
        3'b101:
                segment <= display(key_cnt/48%100/10);
        3'b1110:
                segment <= display(key_cnt/48%10);
        default:segment <= display(key_cnt%10);
        endcase
end
function[7:0] display;//其中不能包含非阻塞赋值
input[3:0] number;
         case(number)
                4'b0000:display = 8'b00111111;
                4'b0001:display = 8'b00000110;
                4'b0010:display = 8'b01011011;
                4'b0011:display = 8'b01001111;
                4'b0100:display = 8'b01100110;
                4'b0101:display = 8'b01101101;
                4'b0110:display = 8'b01111101;
                4'b0111:display = 8'b00000111;
                4'b1000:display = 8'b01111111;
                4'b1001:display = 8'b01101111;
                default:display = 8'b00000000;//共阴极数码显示
        endcase
endfunction
endmodule
10kHz  占空比56%
10kHz  占空比96%
板子显示
此帖出自FPGA/CPLD论坛
