3006|1
39
ADC122S021的时序问题 [复制链接]
uint ADC12_Config(unsigned char temp) { unsigned char i; uint num,tmp=0x000; CS_0; SCLK_1; for(i=0;i<8;i++) { num=temp & 0x80; if(num) DIN_1; else DIN_0; SCLK_0; temp<<=1; delay_us(); SCLK_1; delay_us(); switch(i) { case 4: tmp |= (DOUT<<11); break; case 5: tmp |= (DOUT<<10); break; case 6: tmp |= (DOUT<<9); break; case 7: tmp |= (DOUT<<8); break; } } for(i=0;i<8;i++) { tmp |= (DOUT<<(7-i)); SCLK_1; delay_us(); SCLK_0; } CS_1; return tmp; } 这样去写驱动程序 出不来啊 求解释
请问这个问题解决了吗 ,我好像也是无法运行,能把正常的程序给我看看吗!!!谢谢,QQ: 916208723@qq。com  详情 回复 发表于 2014-11-21 08:46
