3801|3
854
Android开机启动流程初探 [复制链接]
Android开机启动流程初探
l  Init进程
Android系统在启动时首先会启动Linux系统,引导加载Linux Kernel并启动init进程。Init进程是一个由内核启动的用户级进程,是Android系统的第一个进程。该进程的相关代码在platform\system\core\init\init.c。在main函数中,有如下代码:
[url=" title=][/url]
    open_devnull_stdio();
    log_init();
    INFO("reading config file\n");
    init_parse_config_file("/init.rc");
    /* pull the kernel commandline and ramdisk properties file in */
    import_kernel_cmdline(0);
    get_hardware_name(hardware, &revision);
    snprintf(tmp, sizeof(tmp), "/init.%s.rc", hardware);
    init_parse_config_file(tmp);[url=" title=][/url]
    这里会加载解析init.rc和init.hardware.rc两个初始化脚本。*.rc文件定义了在init进程中需要启动哪些进程服务和执行哪些动作。其详细说明参见platform\system\core\init\reademe.txt。init.rc见如下定义:
service servicemanager /system/bin/servicemanager
    user system
    critical
    onrestart restart zygote
    onrestart restart media
service vold /system/bin/vold
    socket vold stream 0660 root mount
    ioprio be 2
service netd /system/bin/netd
    socket netd stream 0660 root system
    socket dnsproxyd stream 0660 root inet
service debuggerd /system/bin/debuggerd
service ril-daemon /system/bin/rild
    socket rild stream 660 root radio
    socket rild-debug stream 660 radio system
    user root
    group radio cache inet misc audio sdcard_rw
service zygote /system/bin/app_process -Xzygote /system/bin --zygote --start-system-server
    socket zygote stream 666
    onrestart write /sys/android_power/request_state wake
    onrestart write /sys/power/state on
    onrestart restart netd
service drm /system/bin/drmserver
    user drm
    group system root inet[url=" title=][/url]
具体解析过程见platform\system\core\init\Init_parser.c。解析所得服务添加到service_list中,动作添加到action_list中。
接下来在main函数中执行动作和启动进程服务:
        execute_one_command();
        restart_processes()
通常init过程需要创建一些系统文件夹并启动USB守护进程、Android Debug Bridge守护进程、Debug守护进程、ServiceManager进程、Zygote进程等。
l  ServiceManager进程
ServiceManager进程是所有服务的管理器。由init.rc对ServiceManager的描述service servicemanager /system/bin/servicemanager可知servicemanager进程从platform\frameworks\base\cmd\servicemanager\Service_manager.cpp启动。在main函数中有如下代码:
int main(int argc, char **argv)
    struct binder_state *bs;
    void *svcmgr = BINDER_SERVICE_MANAGER;
    bs = binder_open(128*1024);
    if (binder_become_context_manager(bs)) {
        LOGE("cannot become context manager (%s)\n", strerror(errno));
        return -1;
    svcmgr_handle = svcmgr;
    binder_loop(bs, svcmgr_handler);
    return 0;
}[url=" title=][/url]
首先调用binder_open()打开Binder设备(/dev/binder),调用binder_become_context_manager()把当前进程设置为ServiceManager。ServiceManager本身就是一个服务。
int binder_become_context_manager(struct binder_state *bs)
    return ioctl(bs->fd, BINDER_SET_CONTEXT_MGR, 0);
    最后binder_loop()进入循环状态,并设置svcmgr_handler回调函数等待添加、查询、获取服务等请求。
l  Zygote进程
         Zygote进程用于产生其他进程。由init.rc对zygote的描述service zygot /system/bin/app_process可知zygote进程从platfrom\frameworks\base\cmds\app_process\App_main.cpp启动。在main函数中有如下代码:
        if (0 == strcmp("--zygote", arg)) {
            bool startSystemServer = (i < argc) ?
                    strcmp(argv, "--start-system-server") == 0 : false;
            setArgv0(argv0, "zygote");
            set_process_name("zygote");
            runtime.start("com.android.internal.os.ZygoteInit",
                startSystemServer);
        } else {
            set_process_name(argv0);
            runtime.mClassName = arg;
            // Remainder of args get passed to startup class main()
            runtime.mArgC = argc-i;
            runtime.mArgV = argv+i;
            LOGV("App process is starting with pid=%d, class=%s.\n",
                 getpid(), runtime.getClassName());
            runtime.start();
    首先创建AppRuntime,即AndroidRuntime,建立了一个Dalvik虚拟机。通过这个runtime传递com.android.internal.os.ZygoteInit参数,从而由Dalvik虚拟机运行ZygoteInit.java的main(),开始创建Zygote进程。在其main()中,如下所示:
            registerZygoteSocket();
            EventLog.writeEvent(LOG_BOOT_PROGRESS_PRELOAD_START,
                SystemClock.uptimeMillis());
            preloadClasses();
            //cacheRegisterMaps();
            preloadResources();
            EventLog.writeEvent(LOG_BOOT_PROGRESS_PRELOAD_END,
            // Finish profiling the zygote initialization.
            SamplingProfilerIntegration.writeZygoteSnapshot();
            // Do an initial gc to clean up after startup
            gc();
            // If requested, start system server directly from Zygote
            if (argv.length != 2) {
                throw new RuntimeException(argv[0] + USAGE_STRING);
            if (argv[1].equals("true")) {
                startSystemServer();
            } else if (!argv[1].equals("false")) {
    首先通过registerZygoteSocket()登记端口,接着preloadClasses()装载相关类。这里大概要装载1000多个类,具体装载类见platform\frameworks\base\preloaded-classes。这个文件有WritePreloadedClassFile类自动生成。分析该类的main函数,有如下一段筛选类的代码:
        // Preload classes that were loaded by at least 2 processes. Hopefully,
// the memory associated with these classes will be shared.
        for (LoadedClass loadedClass : root.loadedClasses.values()) {
            Set names = loadedClass.processNames();
            if (!Policy.isPreloadable(loadedClass)) {
                continue;
            if (names.size() >= MIN_PROCESSES ||
                    (loadedClass.medianTimeMicros() > MIN_LOAD_TIME_MICROS && names.size() > 1)) {
                toPreload.add(loadedClass);
        int initialSize = toPreload.size();
        System.out.println(initialSize
                + " classses were loaded by more than one app.");
        // Preload eligable classes from applications (not long-running
// services).
        for (Proc proc : root.processes.values()) {
            if (proc.fromZygote() && !Policy.isService(proc.name)) {
                for (Operation operation : proc.operations) {
                    LoadedClass loadedClass = operation.loadedClass;
                    if (shouldPreload(loadedClass)) {
其中MIN_LOAD_TIME_MICROS等于1250,当类的装载时间大于1.25ms,则需要预装载。
Policy.isPreloadable()定于如下:
    /**Reports if the given class should be preloaded. */
    public static boolean isPreloadable(LoadedClass clazz) {
        return clazz.systemClass && !EXCLUDED_CLASSES.contains(clazz.name);
其中EXCLUDED_CLASSES如下定义:
     * Classes which we shouldn't load from the Zygote.
    private static final Set EXCLUDED_CLASSES
            = new HashSet(Arrays.asList(
        // Binders
        "android.app.AlarmManager",
        "android.app.SearchManager",
        "android.os.FileObserver",
        "com.android.server.PackageManagerService$AppDirObserver",
        // Threads
        "android.os.AsyncTask",
        "android.pim.ContactsAsyncHelper",
        "java.lang.ProcessManager"
    ));[url=" title=][/url]
这几个Binders和Thread是不会被预加载的。
    另外还有一些application需要装载,要求满足条件proc.fromZygote()且不是属于常驻内存的服务。SERVICES定义如下:
     * Long running services. These are restricted in their contribution to the
     * preloader because their launch time is less critical.
    // TODO: Generate this automatically from package manager.
    private static final Set SERVICES = new HashSet(Arrays.asList(
        "system_server",
        "com.google.process.content",
        "android.process.media",
        "com.android.bluetooth",
        "com.android.calendar",
        "com.android.inputmethod.latin",
        "com.android.phone",
        "com.google.android.apps.maps.FriendService", // pre froyo
        "com.google.android.apps.maps:FriendService", // froyo
        "com.google.android.apps.maps.LocationFriendService",
        "com.google.android.deskclock",
        "com.google.process.gapps",
        "android.tts"
         preloaded-classes是在下载源码的时候生成,WritePreloadedClassFile类并没有被用到,但可以通过这个类了解Android系统对预加载类的默认要求,参考修改preloaded-classes文件,减少开机初始化时要预加载的类,提高开机速度。
最后来通过startSystemServer()启动SystemServer进程。见如下代码:
        /* Hardcoded command line to start the system server */
        String args[] = {
            "--setuid=1000",
            "--setgid=1000",
            "--setgroups=1001,1002,1003,1004,1005,1006,1007,1008,1009,1010,1018,3001,3002,3003",
            "--capabilities=130104352,130104352",
            "--runtime-init",
            "--nice-name=system_server",
            "com.android.server.SystemServer",
        ZygoteConnection.Arguments parsedArgs = null;
        int pid;
        try {
            parsedArgs = new ZygoteConnection.Arguments(args);
             * Enable debugging of the system process if *either* the command line flags
             * indicate it should be debuggable or the ro.debuggable system property
             * is set to "1"
            int debugFlags = parsedArgs.debugFlags;
            if ("1".equals(SystemProperties.get("ro.debuggable")))
                debugFlags |= Zygote.DEBUG_ENABLE_DEBUGGER;
            /* Request to fork the system server process */
            pid = Zygote.forkSystemServer(
                    parsedArgs.uid, parsedArgs.gid,
                    parsedArgs.gids, debugFlags, null,
                    parsedArgs.permittedCapabilities,
                    parsedArgs.effectiveCapabilities)[url=" title=][/url]
         Zygote包装了Linux的fork。forkSystemServer()调用forkAndSpecialize(),最终穿过虚拟机调用platform\dalvik\vm\native\dalvik_system_Zygote.c中Dalvik_dalvik_system_Zygote_forkAndSpecialize()。由dalvik完成fork新的进程。
       main()最后会调用runSelectLoopMode(),进入while循环,由peers创建新的进程。
l  SystemService进程
       SystemService用于创建init.rc定义的服务之外的所有服务。在main()的最后有如下代码:
        // The system server has to run all of the time, so it needs to be
// as efficient as possible with its memory usage.
        VMRuntime.getRuntime().setTargetHeapUtilization(0.8f);
        System.loadLibrary("android_servers");
        init1(args);
Init1()是在native空间实现的,用于启动native空间的服务,其实现在com_android_server_SystemServer.cpp中的android_server_SystemServer_init1():
static void android_server_SystemServer_init1(JNIEnv* env, jobject clazz)
    system_init();
    而system_init()服务初始化创建native层的各个服务:
    // Start the sensor service
    SensorService::instantiate();
    // On the simulator, audioflinger et al don't get started the
// same way as on the device, and we need to start them here
    if (!proc->supportsProcesses()) {
        // Start the AudioFlinger
        AudioFlinger::instantiate();
        // Start the media playback service
        MediaPlayerService::instantiate();
        // Start the camera service
        CameraService::instantiate();
        // Start the audio policy service
        AudioPolicyService::instantiate();
    最后通过如下代码:
    LOGI("System server: starting Android services.\n");
    runtime->callStatic("com/android/server/SystemServer", "init2");
回到SystemServer.java,调用init2():
    public static final void init2() {
        Slog.i(TAG, "Entered the Android system server!");
        Thread thr = new ServerThread();
        thr.setName("android.server.ServerThread");
        thr.start();
         Init2启动一个线程,专门用来启动java空间的所有服务。如下代码所示启动部分服务:
            Slog.i(TAG, "Content Manager");
            ContentService.main(context,
                    factoryTest == SystemServer.FACTORY_TEST_LOW_LEVEL);
            Slog.i(TAG, "System Content Providers");
            ActivityManagerService.installSystemProviders();
            Slog.i(TAG, "Battery Service");
            battery = new BatteryService(context);
            ServiceManager.addService("battery", battery);
            Slog.i(TAG, "Lights Service");
            lights = new LightsService(context);
            Slog.i(TAG, "Vibrator Service");
            ServiceManager.addService("vibrator", new VibratorService(context));
            // only initialize the power service after we have started the
// lights service, content providers and the battery service.
            power.init(context, lights, ActivityManagerService.getDefault(), battery);
            Slog.i(TAG, "Alarm Manager");
            AlarmManagerService alarm = new AlarmManagerService(context);
            ServiceManager.addService(Context.ALARM_SERVICE, alarm);[url=" title=][/url]
并且把这些服务添加到ServiceManager中,以便管理和进程间通讯。
在该线程后半部分,ActivityManagerService会等待AppWidget、WallPaper、IMM等systemReady后调用自身的systemReady()。
            ((ActivityManagerService)ServiceManager.getService("activity"))
                    .setWindowManager(wm);
            // Skip Bluetooth if we have an emulator kernel
// TODO: Use a more reliable check to see if this product should
// support Bluetooth - see bug 988521
            if (SystemProperties.get("ro.kernel.qemu").equals("1")) {
                Slog.i(TAG, "Registering null Bluetooth Service (emulator)");
                ServiceManager.addService(BluetoothAdapter.BLUETOOTH_SERVICE, null);
            } else if (factoryTest == SystemServer.FACTORY_TEST_LOW_LEVEL) {
                Slog.i(TAG, "Registering null Bluetooth Service (factory test)");
            } else {
                Slog.i(TAG, "Bluetooth Service");
                bluetooth = new BluetoothService(context);
                ServiceManager.addService(BluetoothAdapter.BLUETOOTH_SERVICE, bluetooth);
                bluetooth.initAfterRegistration();
                bluetoothA2dp = new BluetoothA2dpService(context, bluetooth);
                ServiceManager.addService(BluetoothA2dpService.BLUETOOTH_A2DP_SERVICE,
                                          bluetoothA2dp);
                int bluetoothOn = Settings.Secure.getInt(mContentResolver,
                    Settings.Secure.BLUETOOTH_ON, 0);
                if (bluetoothOn > 0) {
                    bluetooth.enable();
    而在ActivityManagerService的systemReady()最后会执行如下代码:
            mMainStack.resumeTopActivityLocked(null);
    由于Activity管理栈为空,因此启动Launcher。
        // Find the first activity that is not finishing.
        ActivityRecord next = topRunningActivityLocked(null);
        // Remember how we'll process this pause/resume situation, and ensure
// that the state is reset however we wind up proceeding.
        final boolean userLeaving = mUserLeaving;
        mUserLeaving = false;
        if (next == null) {
            // There are no more activities!  Let's just start up the
// Launcher...
            if (mMainStack) {
                return mService.startHomeActivityLocked();
    在startHomeActivityLocked()中创建一个带Category为CATEGORY_HOME的Intent,由此去启动相应Activity,即Launcher。
        Intent intent = new Intent(
            mTopAction,
            mTopData != null ? Uri.parse(mTopData) : null);
        intent.setComponent(mTopComponent);
        if (mFactoryTest != SystemServer.FACTORY_TEST_LOW_LEVEL) {
            intent.addCategory(Intent.CATEGORY_HOME);
    这样,Android系统便启动起来进入到待机界面。
呵呵,我也是初学者,以前搞wince的,现在过来不简单。现在也算是入门级别。高级的还不会玩。  详情 回复 发表于 2013-7-13 00:53
个人签名如果对linux,Android,wince 等嵌入式底层有兴趣的,请加这个QQ群吧,群号:27100460
384
还没学android  mark
4996
裸片初长成(初级)
不错,学习了。
个人签名我的博客
468
原帖由 upc_arm 于 2013-7-11 13:22 发表
还没学android  mark
