为什么打开使用CONFIG_S3C_DEV_ADC1这段代码后S5pv210 linux 就不启动了?
#if defined(CONFIG_S3C_DEV_ADC1)
tmp = readl(adc->regs + S3C2410_ADCCON);
tmp |= S3C64XX_ADCCON_TSSEL;
writel(tmp, adc->regs + S3C2410_ADCCON);
adc->regs += 0x1000;
printk("CONFIG_S3C_DEV_ADC1 set touch1 S3C2410_ADCCON=0x%x \n",readl(adc->regs + S3C2410_ADCCON));// 2013.06.13
#endif
然后串口打印信息就到这里停住了
OK
U-Boot 1.3.4 (Jun 13 2013 - 14:29:16) for SMDKV210
CPU: S5PV210@1000MHz(OK)
APLL = 1000MHz, HclkMsys = 200MHz, PclkMsys = 100MHz
MPLL = 667MHz, EPLL = 80MHz
HclkDsys = 166MHz, PclkDsys = 83MHz
HclkPsys = 133MHz, PclkPsys = 66MHz
SCLKA2M = 200MHz
Serial = CLKUART
Board: SMDKV210
DRAM: 1 GB
Flash: 8 MB
SD/MMC: 3781MB
NAND: 1024 MB
The input address don't need a virtual-to-physical translation : 23e9d2a0
In: serial
Out: serial
Err: serial
checking mode for fastboot ...
Hit any key to stop autoboot: 0
reading kernel.. 1073, 8192
MMC read: dev # 0, block # 1073, count 8192 ...8192 blocks read: OK
completed
reading RFS.. 9265, 3072
MMC read: dev # 0, block # 9265, count 3072 ...The input address don't need a virtual-to-physical translation : 21a00000
3072 blocks read: OK
completed
Boot with zImage
get_format
-------- 1 --------
## Loading init Ramdisk from Legacy Image at 21a00000 ...
Image Name: ramdisk
Created: 2013-06-05 11:52:27 UTC
Image Type: ARM Linux RAMDisk Image (uncompressed)
Data Size: 163243 Bytes = 159.4 kB
Load Address: 30a00000
Entry Point: 30a00000
Verifying Checksum ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
后来发现是adc->regs += 0x1000; 这句存在问题,
屏蔽它就可以正常启动了,
不过想不明白,这个不应该会导致不启动啊。咋回事呢?
