External clock mode1 (TI1 or TI2 pins)
In this mode the external clock will be applied on timer input TI1 pin or TI2 pin. To do this:
1. Configure the timers to use the TIx pin as input:
a) Select the pin to be used by writing CCxS bits in the TIMx_CCMR1 register.
b) Select the polarity of the input:
For the STM32F10x family: by writing CCxP in the TIMx_CCER register to select
the rising or the falling edge;
For the other families: by writing CCxP and CCxNP in the TIMx_CCER register
to select the rising/falling edge, or both edges(a).
c) Configure the filter and the prescaler if needed by writing the ICxF[3:0] bits in the
TIMx_CCMR1:
Select the timer TIx as the trigger input source by writing TS bits in the
TIMx_SMCR register.
Select the external clock mode1 by writing SMS=111 in the TIMx_SMCR register.
Enable the corresponding channel by setting the CCEx bit in the TIMx_CCER
register.
2. Select the timer TIx as the trigger input source by writing TS bits in the TIMx_SMCR
register.
3. Select the external clock mode1 by writing SMS=111 in the TIMx_SMCR register.
External clock mode2 (ETR pin)
The external clock mode2 uses the ETR pin as timer input clock. To use this feature:
1. Select the external clock mode2 by writing ECE = 1 in the TIMx_SMCR register.
2. Configure, if needed, the prescaler, the filter and the polarity by writing ETPS [1:0], ETF
[3:0] and ETP in the TIMx_SMCR register.
详情
发表于 2013-5-19 00:15
点评 | |
此帖出自stm32/stm8论坛
个人签名工程 = 数学+物理+经济
此帖出自stm32/stm8论坛
个人签名工程 = 数学+物理+经济
曾经的版主且威望大于2000,或对EEWORLD论坛有突出贡献的坛友
