2896|0
5276
裸片初长成(中级)
谁能详解这段CCS的Grace产生的代码? [复制链接]
  1. /* verify that the MSP430 headers included support the code that's generated */
  2. #if defined(__TI_COMPILER_VERSION__)
  3.   /* pragma required to suppress TI warning that #warning is unrecognized */
  4.   #pragma diag_suppress 11
  5. #endif
  6. #if __MSP430_HEADER_VERSION__ < 1066
  7.   #if defined(__TI_COMPILER_VERSION__)
  8.     #warn The MSP430 headers included may be incompatible with the generated source files.  If the value of __MSP430_HEADER_VERSION__, declared by msp430.h, is less than 1066, please update your version of the msp430 headers.
  9.   #elif defined(__GNUC__) || defined(__IAR_SYSTEMS_ICC__)
  10.     #warning The MSP430 headers included may be incompatible with the generated source files.  If the value of __MSP430_HEADER_VERSION__, declared by msp430.h, is less than 1066, please update your version of the msp430 headers.
  11.   #else
  12.     /* if we can't just warn, resort to ANSI C's #error */
  13.     #error The MSP430 headers included may be incompatible with the generated source files.  If the value of __MSP430_HEADER_VERSION__, declared by msp430.h, is less than 1066, please update your version of the msp430 headers.
  14.   #endif
  15. #endif
  16. #if defined(__TI_COMPILER_VERSION__)
  17.   /* pragma required to restore TI warnings about unrecognized directives */
  18.   #pragma diag_default 11
  19. #endif
复制代码
原来没看明白以为有错,原来没错
[ 本帖最后由 wangfuchong 于 2013-1-16 19:26 编辑 ]
个人签名没工作,没女人老婆,没宽带 ,  没钱
