2414|0
收藏 请教一下AVR或C51接USB键盘的问题 [复制链接]
想要利用现在市面上出售的USB键盘作为输入设备,向单片机输入数据,涉及到单片机和USB通信的问题……读了USB1.1协议,反而更加迷惑了,网上也搜不到(请不要和我说搜“HID”之类的,如果能搜到,请回复搜到的网址)
手头有一个程序,是AVR利用PS/2接口和键盘连接的
大家帮忙看一下怎么改?(或者有没有USB转接为PS/2的电路)
文件:main.c
C/C++ code
22
23
24
27
28
29
32
33
34
37
38
39
42
43
44
45
46
47
48
49
52
53
54
55
56
57
58
59
62
63
64
65
66
67
75
77
78
79
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
102
103
104
105
106
107
108
109
Chip type           : AT90S4434
Clock frequency     : 8,000000 MHz
Memory model        : Tiny
Internal SRAM size  : 256
External SRAM size  : 0
Data Stack size     : 64
#include <90s4434.h>
#include "kb.h"
#include
// Alphanumeric LCD Module functions
#asm
   .equ __lcd_port=0x15
#endasm
#include
// Declare your global variables here
void main(void)
// Declare your local variables here
    unsigned char key;
// Input/Output Ports initialization
// Port A
PORTA=0x00;
DDRA=0x00;
// Port B
PORTB=0x00;
DDRB=0x00;
// Port C
PORTC=0x00;
DDRC=0x00;
// Port D
PORTD=0x00;
DDRD=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Output Compare
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer 1 Stopped
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
TCCR2=0x00;
ASSR=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Oon
// INT1: Off
GIMSK= 0x40;        // Enable INT0 interrupt
MCUCR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
// LCD module initialization
//lcd_init(20);            // Init 20 Zeichendisplay
lcd_init(16);         // Init 16 Zeichendisplay
InitKeyBoard();               // Initialize keyboard reception
while(1)
        key = getchar_kb();
        lcd_putchar(key);
        delay_ms(5);
文件:kb.c
C/C++ code
22
23
24
27
28
29
32
33
34
37
38
39
42
43
44
45
46
47
48
49
52
53
54
55
56
57
58
59
62
63
64
65
66
67
75
77
78
79
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
** low level kexboard routines                VERSION 1.0
#include "kb.h"
#include "scancodes.h"
#define BUFF_SIZE 64
unsigned char edge, bitcount;                // 0 = neg.  1 = pos.
unsigned char kb_buffer[BUFF_SIZE];
unsigned char *inpt, *outpt;
unsigned char buffcnt;
void InitKeyBoard(void)
    inpt =  kb_buffer;                        // Initialize buffer
    outpt = kb_buffer;
    buffcnt = 0;
    MCUCR = 2;                                // INT0 interrupt on falling edge
    edge = 0;                                // 0 = falling edge  1 = rising edge
    bitcount = 11;
    #asm("sei")                              // interrupt enable
interrupt [EXT_INT0] void INT0_interrupt(void)
    static unsigned char data;                // Holds the received scan code
        if(bitcount < 11 && bitcount > 2)    // Bit 3 to 10 is data. Parity bit,
        {                                    // start and stop bits are ignored.
            data = (data >> 1);
            if(PIND & 8)
                data = data | 0x80;            // Store a '1'
        if(--bitcount == 0)                    // All bits received
            decode(data);
            bitcount = 11;
void decode(unsigned char sc)
    static unsigned char is_up=0, shift = 0, mode = 0;
    unsigned char i;
    if (!is_up)                // Last data received was the up-key identifier
        switch (sc)
          case 0xF0 :        // The up-key identifier
            is_up = 1;
            break;
          case 0x12 :        // Left SHIFT
            shift = 1;
            break;
          case 0x59 :        // Right SHIFT
            shift = 1;
            break;
          case 0x05 :        // F1
            if(mode == 0)
                mode = 1;    // Enter scan code mode
            if(mode == 2)
                mode = 3;    // Leave scan code mode
            break;
          default:
            if(mode == 0 || mode == 3)        // If ASCII mode
                if(!shift)                    // If shift not pressed,
                {                            // do a table look-up
                    for(i = 0; unshifted[0]!=sc && unshifted[0]; i++);
                    if (unshifted[0] == sc) {
                        put_kbbuff(unshifted[1]);
                } else {                    // If shift pressed
                    for(i = 0; shifted[0]!=sc && shifted[0]; i++);
                    if (shifted[0] == sc) {
                        put_kbbuff(shifted[1]);
            } else{                            // Scan code mode
                print_hexbyte(sc);            // Print scan code
                put_kbbuff(' ');
            break;
    } else {
        is_up = 0;                            // Two 0xF0 in a row not allowed
        switch (sc)
            shift = 0;
            break;
            shift = 0;
            break;
          case 0x05 :                        // F1
            if(mode == 1)
                mode = 2;
            if(mode == 3)
                mode = 0;
            break;
          case 0x06 :                        // F2
           // clr();
            break;
void put_kbbuff(unsigned char c)
    if (buffcnt     {
        *inpt = c;                                // Put character into buffer
        inpt++;                                    // Increment pointer
        buffcnt++;
        if (inpt >= kb_buffer + BUFF_SIZE)        // Pointer wrapping
            inpt = kb_buffer;
int getchar_kb(void)
    int byte;
    while(buffcnt == 0);                        // Wait for data
    byte = *outpt;                                // Get byte
    outpt++;                                    // Increment pointer
    if (outpt >= kb_buffer + BUFF_SIZE)            // Pointer wrapping
        outpt = kb_buffer;
    buffcnt--;                                    // Decrement buffer count
    return byte;
void print_hexbyte(unsigned char i)
    unsigned char h, l;
    h = i & 0xF0;               // High nibble
    h = h>>4;
    h = h + '0';
    if (h > '9')
        h = h + 7;
    l = (i & 0x0F)+'0';         // Low nibble
    if (l > '9')
        l = l + 7;
    put_kbbuff(h);
    put_kbbuff(l);
文件kb.h
C/C++ code?
// Keyboard communication routines
#ifndef __KB_INCLUDED
#define __KB_INCLUDED
#define CLOCK   2
#define DATAPIN 3
#define ISC00 0
#define ISC01 1
void InitKeyBoard(void);
interrupt [EXT_INT0] void INT0_interrupt(void);
void decode(unsigned char sc);
void put_kbbuff(unsigned char c);
int getchar_kb(void);
void print_hexbyte(unsigned char i);
#endif
文件:scancodes.h
C/C++ code
22
23
24
27
28
29
32
33
34
37
38
39
42
43
44
45
46
47
48
49
52
53
54
55
56
57
58
59
62
63
64
65
66
67
75
77
78
79
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
// Unshifted characters
flash unsigned char unshifted[68][2] = {
0x0d,9,
0x0e,'|',
0x15,'q',
0x16,'1',
0x1a,'z',
0x1b,'s',
0x1c,'a',
0x1d,'w',
0x1e,'2',
0x21,'c',
0x22,'x',
0x23,'d',
0x24,'e',
0x25,'4',
0x26,'3',
0x29,' ',
0x2a,'v',
0x2b,'f',
0x2c,'t',
0x2d,'r',
0x2e,'5',
0x31,'n',
0x32,'b',
0x33,'h',
0x34,'g',
0x35,'y',
0x36,'6',
0x39,',',
0x3a,'m',
0x3b,'j',
0x3c,'u',
0x3d,'7',
0x3e,'8',
0x41,',',
0x42,'k',
0x43,'i',
0x44,'o',
0x45,'0',
0x46,'9',
0x49,'.',
0x4a,'-',
0x4b,'l',
0x4c,'?,
0x4d,'p',
0x4e,'+',
0x52,'?,
0x54,'?,
0x55,'\\',
0x5a,13,
0x5b,'?,
0x5d,'\\',
0x61,'<',
0x66,8,
0x69,'1',
0x6b,'4',
0x6c,'7',
0x70,'0',
0x71,',',
0x72,'2',
0x73,'5',
0x74,'6',
0x75,'8',
0x79,'+',
0x7a,'3',
0x7b,'-',
0x7c,'*',
0x7d,'9',
0,0
// Shifted characters
flash unsigned char shifted[68][2] = {
0x0d,9,
0x0e,'?,
0x15,'Q',
0x16,'!',
0x1a,'Z',
0x1b,'S',
0x1c,'A',
0x1d,'W',
0x1e,'"',
0x21,'C',
0x22,'X',
0x23,'D',
0x24,'E',
0x25,'?,
0x26,'#',
0x29,' ',
0x2a,'V',
0x2b,'F',
0x2c,'T',
0x2d,'R',
0x2e,'%',
0x31,'N',
0x32,'B',
0x33,'H',
0x34,'G',
0x35,'Y',
0x36,'&',
0x39,'L',
0x3a,'M',
0x3b,'J',
0x3c,'U',
0x3d,'/',
0x3e,'(',
0x41,';',
0x42,'K',
0x43,'I',
0x44,'O',
0x45,'=',
0x46,')',
0x49,':',
0x4a,'_',
0x4b,'L',
0x4c,'?,
0x4d,'P',
0x4e,'?',
0x52,'?,
0x54,'?,
0x55,'`',
0x5a,13,
0x5b,'^',
0x5d,'*',
0x61,'>',
0x66,8,
0x69,'1',
0x6b,'4',
0x6c,'7',
0x70,'0',
0x71,',',
0x72,'2',
0x73,'5',
0x74,'6',
0x75,'8',
0x79,'+',
0x7a,'3',
0x7b,'-',
0x7c,'*',
0x7d,'9',
0,0
此帖出自51单片机论坛
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
