2758|0
473
求助关于USCI UART的波特率问题.. [复制链接]
4M晶振,要9600波特率...
用波特率计算工具算得:UBR1=0X01;UBR0=0XA0;UCA0MCTLW=0XC000;
怎么不对呢...和PC联系不上...
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // stop watchdog
  // XT1 Setup
  PJSEL0 |= BIT4 + BIT5;
  CSCTL0_H = 0xA5;
  CSCTL1 |= DCOFSEL0 + DCOFSEL1;             // Set max. DCO setting
  CSCTL2 = SELA_0 + SELS_3 + SELM_3;        // set ACLK = XT1; MCLK = DCO=smlk
  CSCTL3 = DIVA_2 + DIVS_0 + DIVM_0;        // set all dividers  1MHZ
  CSCTL4 |= XTS;                //high speed mode
  CSCTL4&=~XT1DRIVE_3;
  CSCTL4 &= ~XT1OFF;
  do
    CSCTL5 &= ~XT1OFFG;
                                            // Clear XT1 fault flag
    SFRIFG1 &= ~OFIFG;
  }while (SFRIFG1&OFIFG);                   // Test oscillator fault flag
  // Configure UART pins
  P2SEL1 |= BIT0 + BIT1;
  P2SEL0 &= ~(BIT0 + BIT1);
  P3OUT=0;
  P3DIR|=BIT4+BIT5+BIT6+BIT7;
  // Configure UART 0
  UCA0CTL1 |= UCSWRST;
  UCA0CTL1 = UCSSEL_1;                      // Set ACLK = 4MHZ as UCBRCLK
  UCA0BR0 = 0xa0;                              // 9600 baud
  UCA0BR1 = 0x01;
  UCA0MCTLW |= 0xc000;
  UCA0CTL1 &= ~UCSWRST;                     // release from reset
  UCA0IE |= UCRXIE;                         // Enable RX interrupt
  _EINT();
没有问题啊...
我估计是波特率设置有问题...
那个MCTLW到底怎么设置...按书上说小数5应该设置为0X6B才是...怎么是0XC0呢..
