6799|26
2781
419
Beaglebone在CCSv5下Connect Target出现错误提示,但还能照常下载程序? [复制链接]
在把需要设置的都设置好后,最后Connect Target的时候出现提示:
然后试试LOAD程序到板子里,居然可以正常运行,能够但不运行。
不知道上面的红色提示是怎么回事?
这个根本就没有问题的,连接完之后本来就是这样的   详情 回复 发表于 2013-10-19 11:29
看上去,楼主的仿真器没设对
怎么解决?该选哪个仿真器?  详情 回复 发表于 2012-11-17 23:13
2781
419
回复 沙发 ddllxxrr 的帖子
怎么解决?该选哪个仿真器?
2781
419
[ 本帖最后由 qinkaiabc 于 2012-11-17 15:19 编辑 ]
2781
419
仿真换XDS100v3不行的
楼主按下旁边的,Test Connect
如果连上了别忘保存,然后再试试
点保存了,而且每一次错误地址都不一样,Test Connection 正常,就是connect target出现错误:“No source available for 0x8ff86854”等  详情 回复 发表于 2012-11-18 08:30
2781
419
回复 6楼 ddllxxrr 的帖子
2781
419
楼主驱动没装好
我肯定
楼主看看我的TEST CONNECT
[Start]
Execute the command:
%ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
C:\DOCUME~1\ADMINI~1.D43\LOCALS~1\APPLIC~1\
    .TI\3333542200\0\0\BrdDat\testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 100- or 510-class product.
This utility will load the adapter 'jioserdesusb.dll'.
The library build date was 'May 30 2012'.
The library build time was '22:52:27'.
The library package version is '5.0.747.0'.
The library component version is '35.34.40.0'.
The controller does not use a programmable FPGA.
The controller has a version number of '4' (0x00000004).
The controller has an insertion length of '0' (0x00000000).
This utility will attempt to reset the controller.
This utility has successfully reset the controller.
-----[Print the reset-command hardware log-file]-----------------------------
The scan-path will be reset by toggling the JTAG TRST signal.
The controller is the FTDI FT2232 with USB interface.
The link from controller to target is direct (without cable).
The software is configured for FTDI FT2232 features.
The controller cannot monitor the value on the EMU[0] pin.
The controller cannot monitor the value on the EMU[1] pin.
The controller cannot control the timing on output pins.
The controller cannot control the timing on input pins.
The scan-path link-delay has been set to exactly '0' (0x0000).
-----[The log-file for the JTAG TCLK output generated from the PLL]----------
There is no hardware for programming the JTAG TCLK frequency.
-----[Measure the source and frequency of the final JTAG TCLKR input]--------
There is no hardware for measuring the JTAG TCLK frequency.
-----[Perform the standard path-length test on the JTAG IR and DR]-----------
This path-length test uses blocks of 512 32-bit words.
The test for the JTAG IR instruction path-length succeeded.
The JTAG IR instruction path-length is 6 bits.
The test for the JTAG DR bypass path-length succeeded.
The JTAG DR bypass path-length is 1 bits.
-----[Perform the Integrity scan-test on the JTAG IR]------------------------
This test will use blocks of 512 32-bit words.
This test will be applied just once.
Do a test using 0xFFFFFFFF.
Scan tests: 1, skipped: 0, failed: 0
Do a test using 0x00000000.
Scan tests: 2, skipped: 0, failed: 0
Do a test using 0xFE03E0E2.
Scan tests: 3, skipped: 0, failed: 0
Do a test using 0x01FC1F1D.
Scan tests: 4, skipped: 0, failed: 0
Do a test using 0x5533CCAA.
Scan tests: 5, skipped: 0, failed: 0
Do a test using 0xAACC3355.
Scan tests: 6, skipped: 0, failed: 0
All of the values were scanned correctly.
The JTAG IR Integrity scan-test has succeeded.
-----[Perform the Integrity scan-test on the JTAG DR]------------------------
The JTAG DR Integrity scan-test has succeeded.
[End]
我是插着卡连接电脑的  详情 回复 发表于 2012-11-18 09:10
[Start] Execute the command: %ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity [Result] -----[Print the board config pathnam  详情 回复 发表于 2012-11-18 09:08
2781
419
回复 10楼 ddllxxrr 的帖子
[Start]
[Result]
C:\Users\Qinkai\AppData\Local\.TI\2479245496\
PLL]----------
input]--------
DR]-----------
[End]
2781
419
回复 10楼 ddllxxrr 的帖子
我是插着卡连接电脑的
2781
419
你把卡先拿下,试下先。我的卡没也行。就是系统总找卡
还有一点都忘了。楼主的芯片选对了吗
虽然出现红色提示No source available for \"0x233b8\" 。。随后我点load下载灯亮程序是可以的,如图。点运行,等就亮了。  详情 回复 发表于 2012-11-18 11:53
能试的都试过了,就是不知道咋回事?:Sweat:  详情 回复 发表于 2012-11-18 11:44
芯片选了AM335X ,Am3359,beaglebone,都一一试过了,卡拔下来试,还是不行,:Sad:  详情 回复 发表于 2012-11-18 11:43
2781
419
回复 15楼 ddllxxrr 的帖子
2781
419
2781
419
回复 15楼 ddllxxrr 的帖子
能试的都试过了,就是不知道咋回事?
2781
419
回复 15楼 ddllxxrr 的帖子
虽然出现红色提示No source available for "0x233b8" 。。随后我点load下载灯亮程序是可以的,如图。点运行,等就亮了。
2781
419
