2248|0
51
编译出错 [复制链接]
 Building configuration: project - Debug
Updating build tree...
Linking
Error[e16]: Segment CSTACK (size: 0x32 align: 0x1) is too long for segment definition. At least 0x19 more bytes needed. The problem occurred while processing the
segment placement command "-Z(DATA)CSTACK+_STACK_SIZE#", where at the moment of placement the available memory ranges were "CODE:267-27f"
   Reserved ranges relevant to this placement:
   200-23b              DATA16_I
   23c-266              DATA16_Z
   267-27f              CSTACK
Error while running Linker
Total number of errors: 1
Total number of warnings: 0
这个是什么错误啊,如何解决,求解;    我是把在另一个片子g2553上的程序写到f2013上的时候发生的这个错误,不知道如何解决!!!
