3142|3
我是新手,请高手看看哪错了 [复制链接]
C:\Documents and Settings\cui\桌面#include
#include
int  tab[]={0x3c,0xf9,0xa4,0xb0,0x99,0x92,0x82,
0xf8,0x80,0x90,0x00};
void see()
{int a,qw,bw,sw,gw;
a=(int)(ADC*5000.0/1024.0);
qw=a/1000;
bw=(a%10)/100;
sw=(a%100)/10;
gw=(a%1000);
PORTD=0x00;PORTC=tab[qw];PORTC&=0x7F;
PORTD=0x02;PORTC=tab[bw];
PORTD=0x04;PORTC=tab[sw];
PORTD=0x06;PORTC=tab[gw];
int main()
{DDRC=0xFF;PORTC=0x00;
DDRD=0xFF;PORTD=0x00;
DDRA=0x00;PORTA=0x00;
ADCSRA=0xE6;ADMUX=0x40;
_delay_ms(10);
while(1);
{PORTC=0x00;
see();_delay_ms(1);}
编程有一点乱 不归范  详情 回复 发表于 2012-10-31 19:15
373
while(1)后面有个分号
我明白了,是while(1){}在优化编译时过不去
95
编程有一点乱 不归范
