6050|5
beaglebone心得六:CCS5安装体会 [复制链接]
我最近看了下linux,觉得特别繁琐。我是个实用主义的人,不是说linux不搞,只是不是时候。
于是想到了那个久违了的TI库。这就必须用到CCS了。
http://software-dl.ti.com/dsps/dsps_public_sw/am_bu/starterware/02_00_00_07/index_FDS.html
从上面的链接可以下载到starterware
当然选windows installer
http://processors.wiki.ti.com/index.php/Download_CCS
从上边的网址选择CCS5,下载,这个好像得认证我是两天后才允许下的
这个分网络版和硬盘安装版 ,我下的是硬盘安装版1.2G,费了我老了时间了。
安装也很慢。
下边是对beaglebone的仿真器设置:
step1:
'View -> Target Configurations'
step2:
在'User Defined'点右键选择 'New Target Configuration'
step3:
为自己的仿真器起个名字及设个路径。
step4:
'Basic -> General Setup -> Connection '选择仿真器型号
'Basic -> General Setup -> Board or Device' 选择 'AM335x'.
step5:
'Basic -> Advanced Setup -> Target Configuration' 在高级选项栏中选中Cortex-A8,并指定GEL文件
我的GEL文件路径为:..\..\..\..\..\am335\tools\gel\AM335x_beaglebone.gel
好了,点SAVe保存一下就好了。
对了,中间那个test Connection可是测一下连接上仿真器没有,以下是我的测试结果:
[Start]
Execute the command:
%ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
C:\DOCUME~1\ADMINI~1.D43\LOCALS~1\APPLIC~1\
    .TI\3333542200\0\0\BrdDat\testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 100- or 510-class product.
This utility will load the adapter 'jioserdesusb.dll'.
The library build date was 'May 30 2012'.
The library build time was '22:52:27'.
The library package version is '5.0.747.0'.
The library component version is '35.34.40.0'.
The controller does not use a programmable FPGA.
The controller has a version number of '4' (0x00000004).
The controller has an insertion length of '0' (0x00000000).
This utility will attempt to reset the controller.
This utility has successfully reset the controller.
-----[Print the reset-command hardware log-file]-----------------------------
The scan-path will be reset by toggling the JTAG TRST signal.
The controller is the FTDI FT2232 with USB interface.
The link from controller to target is direct (without cable).
The software is configured for FTDI FT2232 features.
The controller cannot monitor the value on the EMU[0] pin.
The controller cannot monitor the value on the EMU[1] pin.
The controller cannot control the timing on output pins.
The controller cannot control the timing on input pins.
The scan-path link-delay has been set to exactly '0' (0x0000).
-----[The log-file for the JTAG TCLK output generated from the PLL]----------
There is no hardware for programming the JTAG TCLK frequency.
-----[Measure the source and frequency of the final JTAG TCLKR input]--------
There is no hardware for measuring the JTAG TCLK frequency.
-----[Perform the standard path-length test on the JTAG IR and DR]-----------
This path-length test uses blocks of 512 32-bit words.
The test for the JTAG IR instruction path-length succeeded.
The JTAG IR instruction path-length is 6 bits.
The test for the JTAG DR bypass path-length succeeded.
The JTAG DR bypass path-length is 1 bits.
-----[Perform the Integrity scan-test on the JTAG IR]------------------------
This test will use blocks of 512 32-bit words.
This test will be applied just once.
Do a test using 0xFFFFFFFF.
Scan tests: 1, skipped: 0, failed: 0
Do a test using 0x00000000.
Scan tests: 2, skipped: 0, failed: 0
Do a test using 0xFE03E0E2.
Scan tests: 3, skipped: 0, failed: 0
Do a test using 0x01FC1F1D.
Scan tests: 4, skipped: 0, failed: 0
Do a test using 0x5533CCAA.
Scan tests: 5, skipped: 0, failed: 0
Do a test using 0xAACC3355.
Scan tests: 6, skipped: 0, failed: 0
All of the values were scanned correctly.
The JTAG IR Integrity scan-test has succeeded.
-----[Perform the Integrity scan-test on the JTAG DR]------------------------
The JTAG DR Integrity scan-test has succeeded.
[End]
CCS环境装好后就可快速开发beaglebone啦。呵呵
感谢分享,在学习中。  详情 回复 发表于 2015-5-31 00:20
点赞 关注(1)
1246
楼主和我一样的打算哦!!我用IAR!
anananjjj你也太快了,我刚发完,你就沙发了。比我还快呢:lol  详情 回复 发表于 2012-10-23 23:25
回复 沙发 anananjjj 的帖子
1246
这叫赶得早,不如赶得巧!
5979
个人签名生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙
做一个简单的人,踏实而务实,不沉溺幻想,不庸人自扰
感谢分享,在学习中。
