2314|0
求帮助,我是新手用1602编了一个简易计算器在输入数字键7,4,1时有异常 [复制链接]
1芯积分
程序基本功能+-*/均可实现,只是在每次输入数字键7,4,1中任意一个时,1602显示屏显示的数字不是按地址加一一个挨一个显示,而是莫名其妙的中间有间隔,别的数字都可以正常输入显示,百思不得其解,求高手帮忙看看,不胜感激。
以下为源程序:
#include
typedef  unsigned int uint;
typedef  unsigned char uchar;
sbit dula=P2^6;
sbit wela=P2^7;
sbit lcden=P3^4;
sbit rs=P3^5;
sbit rw=P3^6;
sbit busy=P0^7;
char i,j,temp,num;
long a,b,c;
uchar flag,fuhao;
uchar code table[]={7,8,9,
0,4,5,
6,0,1,
2,3,0,
0,0,0,0
uchar code table1[]={
7,8,9,0x2f-0x30,
4,5,6,0x2a-0x30,
1,2,3,0x2d-0x30,
0x01-0x30,0x3d-0x30,0x3d-0x30,0x2b-0x30,
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void write_com(uchar com)
P0=com;
rs=0;
rw=0;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date)
P0=date;
rs=1;
rw=0;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_str(uchar *p)
while(*p)
  write_date(*p);
  p++;
void init()
lcden=0;
num=-1;
dula=0;
wela=0;
lcden=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
i=0;
j=0;
a=0;
b=0;
c=0;
flag=0;
fuhao=0;
write_com(0x80);
void keyscan()
P3=0xfe;
if(P3!=0xfe)
  delay(10);
  if(P3!=0xfe)
   temp=P3&0xf0;
   switch(temp)
    case 0xe0:num=0;break;
    case 0xd0:num=1;break;
    case 0xb0:num=2;break;
    case 0x70:num=3;break;
  while(P3!=0xfe);
  if(num==0||num==1||num==2)
   if(j!=0)
    write_com(0x01);
    j=0;
   if(flag==0)
    a=a*10+table[num];
   else
    b=b*10+table[num];
  else
   flag=1;
   fuhao=4;
  i=table1[num];
  write_date(0x30+i);
P3=0xfd;
if(P3!=0xfd)
  delay(10);
  if(P3!=0xfd)
   temp=P3&0xf0;
   switch(temp)
    case 0xe0:num=4;break;
    case 0xd0:num=5;break;
    case 0xb0:num=6;break;
    case 0x70:num=7;break;
  while(P3!=0xfd);
  if(num==4||num==5||num==6)
   if(j!=0)
    write_com(0x01);
    j=0;
   if(flag==0)
    a=a*10+table[num];
   else
    b=b*10+table[num];
  else
   flag=1;
   fuhao=3;
  i=table1[num];
  write_date(0x30+i);
P3=0xfb;
if(P3!=0xfb)
  delay(10);
  if(P3!=0xfb)
   temp=P3&0xf0;
   switch(temp)
    case 0xe0:num=8;break;
    case 0xd0:num=9;break;
    case 0xb0:num=10;break;
    case 0x70:num=11;break;
  while(P3!=0xfb);
  if(num==8||num==9||num==10)
   if(j!=0)
    write_com(0x01);
    j=0;
   if(flag==0)
    a=a*10+table[num];
   else
    b=b*10+table[num];
  else
   flag=1;
   fuhao=2;
  i=table1[num];
  write_date(0x30+i);
P3=0xf7;
if(P3!=0xf7)
  delay(10);
  if(P3!=0xf7)
   temp=P3&0xf0;
   switch(temp)
    case 0xe0:num=12;break;
    case 0xd0:num=13;break;
    case 0xb0:num=14;break;
    case 0x70:num=15;break;
  while(P3!=0xf7);
  switch(num)
   case 12:{write_com(0x01);a=0;b=0;c=0;flag=0;fuhao=0;write_com(0x80);}break;
   case 13:{
      if(flag==0)
       a=a*10;
       write_date(0x30);
      else if(flag==1)
       b=b*10;
       write_date(0x30);
     }break;
   case 14:{j=1;
       if(fuhao==1)
       { write_com(0x80+0x4f);
        write_com(0x04);
        c=a+b;
        while(c!=0)
        write_date(0x30+c%10);
        c=c/10;
        write_date(0x3d);
        write_com(0x06);
       else if(fuhao==2)
        write_com(0x04);
        if(a>b) c=a-b;
        else c=b-a;
        while(c!=0)
         c=c/10;
        if(a-b<0)
        write_date(0x2d);
        write_date(0x3d);
        write_com(0x06);
       else if(fuhao==3)
        write_com(0x04);
        c=a*b;
        while(c!=0)
         c=c/10;
        write_date(0x3d);
        a=0;b=0;c=0;flag=0;fuhao=0;write_com(0x06);
       else if(fuhao==4)//除法
        write_com(0x04);
        i=0;
        c=(long)(((float)a*1.0/b)*1000);
        while(c!=0)
         c=c/10;
         i++;
         if(i==3)
         write_date(0x2e);
         if(a         write_date(0x30);
        write_date(0x3d);
      }break;
      case 15:{write_date(0x30+table1[num]);flag=1;fuhao=1;}
      break;
main()
init();
write_str("C51 calculator");
write_com(0xc0);
write_str("By kylelee");
delay(1000);
init();
while(1)
  keyscan();
此帖出自51单片机论坛
中星联华&ADI明日直播
直播主题:大咖面对面,轻松玩转高速ADC性能测试
直播时间:3月25日(周二)14:00
活动奖励:京东卡、双肩包
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 12
