2414|0
Linux-2.6.21 S3c6400中断剖析<五>(原创)-上海嵌入式索漫科技培训教材 [复制链接]
作者:下家山(请尊重原创,转载请注明)  http://www.xiajiashan.com
4.1.2.1 desc->chip->unmask(irq)函数来自哪里?
其实default_startup和default_enable最终调用的是一个函数desc->chip->unmask(irq);那么这个函数在哪里定义的呢?
       在s3c_init_irq中调用了set_irq_chip(irqno, &s3c_irqext_chip);参数s3c_irqext_chip是一个结构体,定义如下:
static struct irq_chip s3c_irqext_chip = {
       .mask = s3c_irqext_mask,
       .unmask = s3c_irqext_unmaskack,
       //.ack = s3c_irqext_maskack,/*old*/
       .ack = s3c_irqext_ack,
       .set_type = s3c_irqext_type,
       .set_wake = s3c_irqext_wake
};因此,在调用set_irq_chip(irqno, &s3c_irqext_chip);这个函数时,就对相应的irq结构体irq_desc进行了回调函数的定义。
4.1.3 关于set_irq_handler函数
 * Set a highlevel flow handler for a given IRQ:
static inline void
set_irq_handler(unsigned int irq, irq_flow_handler_t handle)
       __set_irq_handler(irq, handle, 0, NULL);
}(见/include/linux/irq.h)
void
__set_irq_handler(unsigned int irq, irq_flow_handler_t handle, int is_chained,
                const char *name) (见/kernel/irq/chip.c)
       struct irq_desc *desc;
       unsigned long flags;
       if (irq >= NR_IRQS) {
              printk(KERN_ERR
                     "Trying to install type control for IRQ%d\n", irq);
              return;
       desc = irq_desc + irq;
       if (!handle)
              handle = handle_bad_irq;
       else if (desc->chip == &no_irq_chip) {
              printk(KERN_WARNING "Trying to install %sinterrupt handler "
                     "for IRQ%d\n", is_chained ? "chained " : "", irq);
               * Some ARM implementations install a handler for really dumb
               * interrupt hardware without setting an irq_chip. This worked
               * with the ARM no_irq_chip but the check in setup_irq would
               * prevent us to setup the interrupt at all. Switch it to
               * dummy_irq_chip for easy transition.
              desc->chip = &dummy_irq_chip;
       spin_lock_irqsave(&desc->lock, flags);
       /* Uninstall? */
       if (handle == handle_bad_irq) {
              if (desc->chip != &no_irq_chip)
                     mask_ack_irq(desc, irq);
              desc->status |= IRQ_DISABLED;
              desc->depth = 1;
       desc->handle_irq = handle;/* 这一句很重要,即定义对应irq结构体irq_desc 的回调函数desc->handle_irq ,这样在函数asm_do_IRQ中调用desc_handle_irq(irq, desc)时就调用到这个句柄函数中来了 */
       desc->name = name;
       if (handle != handle_bad_irq && is_chained) {
              desc->status &= ~IRQ_DISABLED;
              desc->status |= IRQ_NOREQUEST | IRQ_NOPROBE;
              desc->depth = 0;
       spin_unlock_irqrestore(&desc->lock, flags);
void set_irq_flags(unsigned int irq, unsigned int iflags)/*见arch/arm/kernel/irq.c*/
              printk(KERN_ERR "Trying to set irq flags for IRQ%d\n", irq);
              return;
       desc->status |= IRQ_NOREQUEST | IRQ_NOPROBE | IRQ_NOAUTOEN;
       if (iflags & IRQF_VALID)
              desc->status &= ~IRQ_NOREQUEST;
       if (iflags & IRQF_PROBE)
              desc->status &= ~IRQ_NOPROBE;
       if (!(iflags & IRQF_NOAUTOEN))
              desc->status &= ~IRQ_NOAUTOEN;
这个函数主要是初始化irq对应结构体irq_desc的status。这在setup_irq中会涉及到。
4.2 中断发生后,kernel具体做了哪些事情
   到这里似乎还没有找到我们第二个问题的答案,但至此我们应该有了一个大概的脉络流程,即从中断发生后,kernel具体做了哪些事情:
        中断发生——>向量地址0xffff0018——>vector_irq——>handler_irq——>asm_do_IRQ——>desc_handle_irq——>desc->handle_irq——>handle_level_irq
4.3 关于handle_level_irq函数
       其实,到这里如果你再往下跟一下就会找到答案。
       在handle_level_irq函数中其原形如下:(见/kernel/irq/chip.c)
 *    handle_level_irq - Level type irq handler
 *    @irq:      the interrupt number
 *    @desc:    the interrupt description structure for this irq
 *    Level type interrupts are active as long as the hardware line has
 *    the active level. This may require to mask the interrupt and unmask
 *    it after the associated handler has acknowledged the device, so the
 *    interrupt line is back to inactive.
void fastcall
handle_level_irq(unsigned int irq, struct irq_desc *desc)
       unsigned int cpu = smp_processor_id();
       struct irqaction *action;
       irqreturn_t action_ret;
       spin_lock(&desc->lock);
       if (unlikely(desc->status & IRQ_INPROGRESS))
              goto out_unlock;
       desc->status &= ~(IRQ_REPLAY | IRQ_WAITING);
       kstat_cpu(cpu).irqs[irq]++;
        * If its disabled or no action available
        * keep it masked and get out of here
       action = desc->action;/*这一句很重要,它从对应irq的结构体irq_desc中取出当前的活动irq,即 desc->action ,而desc->action 即为我们最初在setup_irq 中注册的的那个action */
       if (unlikely(!action || (desc->status & IRQ_DISABLED))) {
              desc->status |= IRQ_PENDING;
              goto out_unlock;
       desc->status |= IRQ_INPROGRESS;
       desc->status &= ~IRQ_PENDING;
       spin_unlock(&desc->lock);
       action_ret = handle_IRQ_event(irq, action);/*这一句就最重要了,其原形见下面*/
       if (!noirqdebug)
              note_interrupt(irq, desc, action_ret);
       desc->status &= ~IRQ_INPROGRESS;
       if (!(desc->status & IRQ_DISABLED) && desc->chip->unmask)
out_unlock:
4.3.1关于handle_IRQ_event函数
 * handle_IRQ_event - irq action chain handler
 * @action:    the interrupt action chain for this irq
 * Handles the action chain of an irq event
(见kernel/irq/handle.c)
irqreturn_t handle_IRQ_event(unsigned int irq, struct irqaction *action)
       irqreturn_t ret, retval = IRQ_NONE;
       unsigned int status = 0;
       handle_dynamic_tick(action);
       if (!(action->flags & IRQF_DISABLED))
              local_irq_enable_in_hardirq();
       do {
              ret = action->handler(irq, action->dev_id);/*这一句就是我们要找的最终答案,还记得在register_irq中有        action->handler = handler;这一句吗,这里面的handler就是我们驱动注册的中断函数,而在register_irq中把它赋值给了action,而在setup_irq中又把action赋值给了全局变量irq_desc */
              if (ret == IRQ_HANDLED)
                     status |= action->flags;
              retval |= ret;
              action = action->next;
       } while (action);
       if (status & IRQF_SAMPLE_RANDOM)
              add_interrupt_randomness(irq);
       local_irq_disable();
       return retval;
2009-2-13   下家山     写于上海.漕河泾
                                   有什么问题可以给我邮件ximenpiaoxue4016@sina.com或加我群198204885
