4065|6
141
万年历带智能闹钟 [复制链接]
uchar sh,f,m,r,y,x,l,k1,k2=0;            //时间时分秒 日月年 星期 定时器溢出标志 两按键
uint n=2010;
uchar Rsh,Rf,Rswitch,Rr,Ry;             //闹铃 日月年 时 分      开关
uint Rn=2010;
extern uchar s1[][5]={"mon ","tue ","wed ","thu ","fri ","sun ","sur "};
extern uchar s2[][10]={"Monday","Tuesday","Wednesday","Thursday","Friday","Saturday","Sunday" };
extern uchar s3[][10]={"        ","January","February","March","April","may","June","July","August","September","October","November","December"};
extern uchar s0[11]="0123456789";
extern void LCD_display(void)           // 适时动态显示
if(k1==0)
  if(Rswitch&&Rn==n&&Ry==y&&Rr==r&&Rsh==sh&&Rf==f)
  while(Rswitch&&Rf==f)
   if(l)
    w_str(0,0,"the time you set");
    w_str(0,1,"is stepping here!");
    PWMGenEnable(PWM_BASE,PWM_GEN_1);
   else
    w_str(0,0,"U can turn off it");
    w_str(0,1,"and refresh it !");
    PWMGenDisable(PWM_BASE,PWM_GEN_1);
  else
    display_addr(0,0);
    w_char(s0[n/1000]);
    w_char(s0[(n%1000)/100]);
    w_char(s0[(n%100)/10]);
    w_char(s0[n%10]);
    w_char('-');
    w_char(s0[y/10]);
    w_char(s0[y%10]);
    w_char('-');
    w_char(s0[r/10]);
    w_char(s0[r%10]);
    w_char(' ');
    w_char('~');
    w_str(12,0,s1[x]);
    w_str(0,1,"Time is ");
    w_char(s0[sh/10]);
    w_char(s0[sh%10]);
    w_char(':');
    w_char(s0[f/10]);
    w_char(s0[f%10]);
    w_char(':');
    w_char(s0[m/10]);
    w_char(s0[m%10]);
if (k2==7)
  if(k1==1)
     w_str(0,0,"Set up the ring:");
   w_str(0,1,"repress it later");
    else if(k1==2)
     w_str(0,0,"Set up the time:");
else if(k2==0)
   if(l)
    if(k1==1)
     w_str(0,0,"Set the second..");
     if(Rswitch)
       w_str(0,1,"     Ring on    ");
     else w_str(0,1,"    Ring off    ");
    if(k1==2)
     display_addr(7,1);
     w_char(s0[m/10]);
     w_char(s0[m%10]);
   else w_str(0,1,"                ");
else if(k2==1)
     w_str(0,0,"Set the minute..");
   if(l)
    if(k1==1)
     display_addr(6,1);
     w_char('~');
     w_char(s0[Rf/10]);
     w_char(s0[Rf%10]);
    if(k1==2)
     display_addr(6,1);
     w_char('~');
     w_char(s0[f/10]);
     w_char(s0[f%10]);
else if(k2==2)
     w_str(0,0,"Set  the  hour..");
   if(l)
    if(k1==1)
     display_addr(6,1);
万年历带智能闹钟.rar
368.71 KB, 下载次数: 109
售价: 1 分芯积分  [记录]
此帖出自51单片机论坛
标记、回去学习学习  详情 回复 发表于 2014-6-7 12:30
标记、回去学习学习
此帖出自51单片机论坛
59
好东西,学习学习
此帖出自51单片机论坛
学习一下.........................
此帖出自51单片机论坛
最近專題在作時鐘的 剛好可以研究 謝謝大大
此帖出自51单片机论坛
21
标记、回去学习学习
此帖出自51单片机论坛
21
标记、回去学习学习
此帖出自51单片机论坛
电源解决方案和技术 | DigiKey 应用探索站
