2703|0
PIC24FJ64GA002 AD不产生中断 帮帮忙吧 大侠们 [复制链接]
#include "p24fxxxx.h"
void init(void)
        CLKDIV = 0x3000;
        AD1PCFG = 0xF5FC;
        AD1CON1 = 0x0000;
        //AD1CHS = 0x000B;
    //AD1CHS = 0x0001;
        AD1CSSL = 0x0A03;
        AD1CON3 = 0x1F02;
        AD1CON2bits.CSCNA = 1;
        AD1CON2bits.SMPI = 3;
        AD1CON1bits.ADON = 1;
        //SRbits.IPL = 2;
        IFS0bits.AD1IF = 0;
        IEC0bits.AD1IE = 1;
        T1CON = 0;
        TMR1 = 0;
        PR1 = 0xFFFF;
        IPC0bits.T1IP = 0x4;
        IFS0bits.T1IF = 0;
        IEC0bits.T1IE = 1;
void delay(int n)
        for(;n!=0;n--)
                asm( "nop");
                asm( "nop");
                asm( "nop");
                asm( "nop");
void ProcADC(void)
                int n,*BufPtr;
                AD1CON1bits.SAMP = 1;
                delay(50);
                AD1CON1bits.SAMP = 0;
                while (IFS0bits.AD1IF==1)
                IFS0bits.AD1IF = 0;
                //while (AD1CON1bits.DONE == 1)
                //AD1CON1bits.DONE = 0;
                BufPtr =(int*)&ADC1BUF0;
                for(n = 0;n<4;n++)
                        vDac[n] = *BufPtr;
                        BufPtr++;
unsigned int tmrCount1;
unsigned int tmrCount2;
void __attribute__ ((interrupt, no_auto_psv)) _T1Interrupt(void)
        IFS0bits.T1IF = 0;
        if (tmrCount1 == 0x000F) {
                adcStrFlg = 1;
                tmrCount1 = 0;
        else {
                tmrCount1++;
        if (tmrCount2 == 0x000F) {
                frontPicRdFlg = 1;
                tmrCount2 = 0;
        else {
                tmrCount2++;
int main(void)
        init();
        ProcADC();
while(1){
          ProcADC();
感觉设置上没有问题了啊   为什么就是没有中断呢   而且和T1的中断还有影响
