2894|0
新人求助 关于WDT中NMI中断的 [复制链接]
这是源代码,NMI中断是不是那个reset按键产生的吗,但按下面代码一运行,按reset的话依然是reset功能
//  MSP430G2xx3 Demo - Basic Clock, Configure RST/NMI as NMI
//  Description: Configure RST/NMI as NMI, hi/lo edge. Flash P1.0  inside of
//  NMI_ISR if NMI occurs. General enable interrupt in status register does
//  not need to be set for NMI. NMIIE does need to be reset, as NMI_ISR
//  automatically clears NMI enable to prevent unintentional stack overflow
//  that could result from, bounce or uncontrolled NMI's.
//  ACLK = n/a, MCLK = SMCLK = DCO ~ 800k
//               MSP430G2xx3
//        /|\|              XIN|-
//         --|RST          XOUT|-
//  D. Dang
//  Texas Instruments Inc.
//  December 2010
//   Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10
#include
void main(void)
  WDTCTL = WDTPW + WDTHOLD + WDTNMI + WDTNMIES;  // WDT off NMI hi/lo
  P1DIR |= 0x01;                            // Set P1.0 to output direction
  P1OUT &= ~0x01;                           // Clear P1.0 LED off
  IE1 |= NMIIE;                             // Enable NMI
  _BIS_SR(LPM0_bits);                       // Enter LPM0
#pragma vector=NMI_VECTOR
__interrupt void nmi_ (void)
  volatile unsigned int i;
  P1OUT |= 0x01;                            // Set P1.0 LED on
  for (i = 20000; i > 0; i--);              // Delay
  IFG1 &= ~NMIIFG;                          // Reclear NMI flag in case bounce
