3216|2
stm32f10x串口初始化 [复制链接]
void USART1_Init(void)
    USART_InitTypeDef USART_InitStructure;
  USART_InitStructure.USART_BaudRate = 115200;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  USART_InitStructure.USART_Clock = USART_Clock_Disable;
  USART_InitStructure.USART_CPOL = USART_CPOL_Low;
  USART_InitStructure.USART_CPHA = USART_CPHA_2Edge;
  USART_InitStructure.USART_LastBit = USART_LastBit_Disable;
  /* Configure the USART1 */
  USART_Init(USART1, &USART_InitStructure);
/* Enable the USART Transmoit interrupt: this interrupt is generated when the
   USART1 transmit data register is empty */
  USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
/* Enable the USART Receive interrupt: this interrupt is generated when the
   USART1 receive data register is not empty */
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); //中断方式接收
  /* Enable USART1 */
  USART_Cmd(USART1, ENABLE);
中断方式操作串口,为什么要把收中断disable?我尝试把它enable,结果设备初始化不成功,哪位大侠给解释下
此帖出自stm32/stm8论坛
这个和51一样的,发送用查询,接受用中断。所以把发送中断失能USART_ITConfig(USART1, USART_IT_TXE, DISABLE);  详情 回复 发表于 2012-7-20 12:02
是发中断
此帖出自stm32/stm8论坛
54
此帖出自stm32/stm8论坛
