2397|0
38
大虾能帮我看下这个程序为什么不转换AD值嘛。 [复制链接]
#include "msp430g2553.h"
#include "1602.h"
#define uchar unsigned char
#define uint unsigned int
#define   Num_of_Results   32
static uint results[Num_of_Results];    //保存ADC转换结果的数组                                                     // is not used for anything.
void Trans_val(uint Hex_Val);
    1602显示字符 和算法滤波的定义
uchar shuzi[] = {"0123456789."};
uchar tishi[] = {"The volt is:"};
              主函数
int main(void)
  WDTCTL = WDTPW + WDTHOLD;  // Stop WDT
  LCD_init();                              //复位1602液晶
  LCD_write_string(2,0,tishi);                  //显示提示信息
  LCD_write_char(11,1,'V');
  ADC10CTL0 = ADC10SHT_2 + ADC10ON + ADC10IE; // ADC10ON, interrupt enabled
  ADC10CTL1 = INCH_1;                       // input A1
  ADC10AE0 |= 0x02;                     // PA.1 ADC option select
  ADC10CTL0 |= ENC + ADC10SC;             // Sampling and conversion start
  _EINT();
    __bis_SR_register(CPUOFF + GIE);        // Clear CPUOFF bit from 0(SR)
函数名称:ADC12ISR
功    能:ADC中断服务函数,在这里用多次平均的
          计算P6.0口的模拟电压数值
参    数:无
返回值  :无
#pragma vector=ADC10_VECTOR
__interrupt void ADC10ISR (void)
  static uint index = 0;
  results[index++] = ADC10MEM;               // Move results
  if(index == Num_of_Results)
        uchar i;
        unsigned long sum = 0;
        index = 0;
        for(i = 0; i < Num_of_Results; i++)
            sum += results;
        sum >>= 5;                            //除以32   2的5次方=32
        Trans_val(sum);
   __bic_SR_register_on_exit(CPUOFF);
函数名称:Trans_val
功    能:将16进制ADC转换数据变换成三位10进制
          真实的模拟电压数据,并在液晶上显示
参    数:Hex_Val--16进制数据
          n--变换时的分母等于2的n次方
返回值  :无
    unsigned long caltmp;
    uint Curr_Volt;
    uchar t1,i;
    uchar ptr[4];
    caltmp = Hex_Val;
    caltmp = (caltmp << 5) + Hex_Val;           //caltmp = Hex_Val * 33
    caltmp = (caltmp << 3) + (caltmp << 1);     //caltmp = caltmp * 10
    Curr_Volt = caltmp >> 12;                   //Curr_Volt = caltmp / 2^n
    ptr[0] = Curr_Volt / 100;                   //Hex->Dec变换
    t1 = Curr_Volt - (ptr[0] * 100);
    ptr[2] = t1 / 10;
    ptr[3] = t1 - (ptr[2] * 10);
    ptr[1] = 10;                                //shuzi表中第10位对应符号"."
    //在液晶上显示变换后的结果
    for(i = 0;i < 4;i++)
      LCD_write_char((6 + i),1,shuzi[ptr]);
我用的是四线驱动12864 测得P1.1口的电压为3.48v  但是显示屏上木有视数啊
