2166|0
2012 New type of led high bay light [复制链接]
LED high bay light, also known as led torch light,Mainly used for led outdoor lighting,led indoor lighting,LED high bay light  with unique 360degree beam angle ensures perfect light distribution, which can be widely used in lots of places, such as warehouse lighgting, indoor playground lighting.gardens lighting, public places lighting,factories lighting, warehouses lighting supermarkets lighting,led garden lighting etc.bbier manufacturing co.,ltd provide wholesale outdoor lighting,Outdoor lighting solutions,is a professional led garden lamp manufacturers.
60w led high bay lighting fixtures,Streamline exterior design, beautiful appearance.Take full advantage of the luminous efficienc.60W LED corn lights Lamp Base: E40 E39 E27 E26.Applications: Indoor using; gardens lighting、supermarket lighting、library lighting、school lighting、stores lighting、factories lighting、park lighting、offices lighting、hospitals lighting、hotels lighting,etc…
1.Beam Angle: 360°
2.Light Source/Count: 520pcs  2833 SMD LED
3.Lamp Base: E40  E39  E27  E26
4.Power Consumption: 63W ±5%
5.LED Luminous Efficiency: >100lm/w
6.Luminous Flux: 6300 lm ±5% ( Tj=70℃,Ta=25℃)
7.Lamp's Efficiency ( %): >95 %
8.Color Temperature Standard: Warm White: 2,700 ~ 3,500 K
   Natural White: 4,000~5,000 K
   Cool  White: 5,500~6,700K
9.Color Rendering Index(CRI): Ra>70
10.LED Emitter Life: 50,000 hours
11.LED Lamp (Light Bulb) Life: 35,000 hours
12.Replacement: CFL  180W
13.Input Voltage: 85-300VAC  / 50-60Hz
14.PF: >0.95
15.Power Efficiency: >87%
16.Working Voltage: 32VDC ±5%
17.Power Consumption (Bulb/LED): 60W ±5%
18.Power Supply: 3W
19.Operating Temperature: ─40 ~ 45℃
20.The Dimensions: ¢128 * 198mm
21.N. W / G.W: 440g /610g
60W led high bay lighting Applications:
60W led high bay light fixtures Advantages:
(1)Beam angle:360deg
(2)Streamline exterior design, beautiful appearance
(3)Take full advantage of the luminous efficienc
(4)Special circuit design, each LED work separately, avoiding the single broken LED influence problem
Web: www.bbier.net   www.bbier.com
