12862|2
求助 关于一些题目 [复制链接]
2.you are communicating with an external device over an I2C bus. The I2C address of the device is 0x40. list the steps you would take to write a 1 in bit 7 of a register at address 02 in the external device without affecting the other bits in that register. You can assume you are using an I2C controller to do the actual I2C bus operations as in the next example. (you will essentially write program comments with appropriate values but you do not need to write the actual assembly language instructions)
       LDR R10,=0x40301688
@read from register 02 from the I2C device adressed in 0x40
    MOV R0,#0X80        @slave adress in the I2C bus is 0x40;
    STR R0,[R10]
    MOV R0,#0x69        @set byte to start a read after write cycle
    STR R0,[R10,#0x8]
    BL POLLTB
    MOV R0,#0X02    @要读入器件内部地址02单元
    STR R0,[R10]
    MOV R0,#0X68
    STR R0,[R10,#0X8]
    BL POLLTB
    MOV R0,#0X81    @设置读入周期@
    STR R0,[R10]
    MOV R0,#0x69    @START=1,STOP=0,TB=1@
    STR R0,[R10,#0x8]
    BL POLLTB
    MOV R0,#0X6A    @只读一个数据@stop=1 TB=1
    STR R0,[R10,#0X8]   @设置开始读入@
    BL POLLTB       @等待读入结束
    LDR R1,[R10]
    MOV R2,#0X80
    ORR R1,R1,R2
    MOV R0,#0X80
    STR R0,[R10]
    MOV R0,#0x69
    STR R0,[R10,#0x8]
    BL POLLTB@
    MOV R0,#0X02    @写入器件内部地址02单元
    STR R0,[R10]
    MOV R0,#0X68
    STR R0,[R10,#0X8]
    BL POLLTB
    MOV R0,R1   @这是写入器件02单元的数据@
    STR R0,[R10]
    MOV R0,#0X6A    @写入后停止,只写一个数据@
    STR R0,[R10,#0X8]
    BL POLLTB       @等响应
 这个题目根据上面的程序。。怎么写算法啊
3.briefly describe the operation of a Successive Approximation type A/D converter and in general terms compare its speed with that of the other types of converters( flash , dual slope, sigma-delta)
4.describe why a low-pass filter is often put in series with the input of an A/D converter that is to be used to digitize rapidly changing signals such as audio frequency sinewave signals.
5.describe the meaning of five of the following terms.
  a. CRC
  b. half-duplex
  c.  snubber circuit
  d. Quantization Error
  e. sigma-delta A/D converter
这题给点中文资料
此帖出自单片机论坛
我想说的楼上的都说了啊  详情 回复 发表于 2007-5-14 09:54
1759
裸片初长成(高级)
Re: 求助 关于一些题目
1 你去看看iic的手册 你就知道算法了 你的这题很简单的 读数据而已 2 选择一个ad 去找找资料就可以了 sigma-delta A/D 这种converter很多就是速度慢点 精度还可以
此帖出自单片机论坛
个人签名南京璞晓电子   www.cpx0.com需要
msn:njlianjian@hotmail.com
1284
Re: 求助 关于一些题目
我想说的楼上的都说了啊
此帖出自单片机论坛
个人签名呼呼...在校应届大四学生,代做电子类毕业设计(测量类、仪器类、控制类、无线通信类、电子产品类、界面设计类、纯论文类等等,一一俱全)。涉及各种单片机软硬件设计、电路模拟分析、FPGA、CPLD、ARM7/ARM9、LINUX、VB/VC++/QT界面等等。包过。。。欢迎咨询。Tel:13957160506。QQ:273437087
