3991|6
6499
管理员
[应用资料]TMP275: 0.5C 数字输出温度传感器 [复制链接]
说明
The TMP275 is a 0.5°C accurate, Two-Wire, serial output temperature sensor available in an MSOP-8 or an SO-8 package. The TMP275 is capable of reading temperatures with a resolution of 0.0625°C.
The TMP275 is SMBus-compatible and allows up to eight devices on one bus. It is ideal for extended temperature measurement in a variety of communication, computer, consumer, environmental, industrial, and instrumentation applications.
The TMP275 is specified for operation over a temperature range of -40°C to +125°C.
特性
    * EIGHT ADDRESSES
    * DIGITAL OUTPUT: Two-Wire Serial Interface
    * RESOLUTION: 9- to 12-Bits, User-Selectable
    * ACCURACY: ±0.5°C (max) from 20°C to +100°C
    * LOW QUIESCENT CURRENT: 50µA, 0.1µA Standby
    * WIDE SUPPLY RANGE: 2.7V to 5.5V
    * SMALL MSOP-8 AND SO-8 PACKAGES
    * NO POWER-UP SEQUENCE REQUIRED; TWO-WIRE BUS PULL-UPS CAN BE ENABLED BEFORE V+
    * APPLICATIONS
          o POWER-SUPPLY TEMPERATURE MONITORING
          o COMPUTER PERIPHERAL THERMAL PROTECTION
          o NOTEBOOK COMPUTERS
          o CELL PHONES
          o BATTERY MANAGEMENT
          o OFFICE MACHINES
          o THERMOSTAT CONTROLS
          o ENVIRONMENTAL MONITORING AND HVAC
          o ELECTROMECHANICAL DEVICE TEMPERATURE
Datahsheet:
0.5°C Digital Out Temperature Sensor.pdf (473.21 KB, 下载次数: 405)
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
好东西啊  详情 回复 发表于 2012-3-15 11:13
个人签名微信搜索公众号“EEWORLDBBS”快去添加关注吧!
多谢楼主分享
 多谢楼主,正用得着。
quantasylum..
2883
The TMP275 is specified for operation over a temperature range of -40°C to +125°C. ACCURACY: ±0.5°C (max) from 20°C to +100°C 请问20°C以下精度是多少?
2883
汗,原来是ACCURACY: ±0.5°C (max) from -20°C to +100°C。楼主把负号给吃了。
57
谁能告诉我这个比DS18B20有哪些优点
242
原帖由 yunbei 于 2012-3-8 20:27 发表 谁能告诉我这个比DS18B20有哪些优点
很明显,功耗低,有效检测温度范围内精度保证。毕竟一分价一分货。
好东西,我收了
个人签名以摆脱无知为起点,以力求专业为目标
好东西啊
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
