STM32F2XX的以太网怎么用。要是谁有中文版的资料也可以贴出来共享下。
Frame check sequence: 4-byte field that contains the cyclic redundancy check (CRC) value. The CRC computation is based on the following fields: source address,
destination address, QTag prefix, length/type, LLC data and PAD (that is, all fields except the preamble, SFD). The generating polynomial is the following: The CRC value of a frame is computed as follows: ● The first 2 bits of the frame are complemented ● The n-bits of the frame are the coefficients of a polynomial M(x) of degree (n – 1). The first bit of the destination address corresponds to the xn – 1 term and the last bit of the data field corresponds to the x0 term ● M(x) is multiplied by x32 and divided by G(x), producing a remainder R(x) of degree ≤ 31 ● The coefficients of R(x) are considered as a 32-bit sequence ● The bit sequence is complemented and the result is the CRC ● The 32-bits of the CRC value are placed in the frame check sequence. The x32 term is the first transmitted, the x0 term is the last one
看得很晕,不知道有谁可以讲解下。。
