7494|3
5015
裸片初长成(初级)
CCS5.2发布 [复制链接]
CCS5.2版本已经发布,相对于之前版本有如下更改:
  • Support on Windows and Linux, including SYS/BIOS, ELF, ULP Advisor, and Flash differential download
  • Now fully supports MSP430G2210
  • Fuse blow for MSP430F1xx, F2xx and F4xx functional
  • Fixed missing device support (479x, 478x, BT5190, new revisions of 1122, 1132)
  • Writing to BSL failed if device was reset after erase (or MSP430_EraseCheck was called)
  • Fixed a bug when writing to FRAM devices with enabled MPU (FR57xx)
  • Fixed a bug that caused erasing and writing to Flash to fail on MSP430F413
  • Port handling changed to work around a problem where a port could not be reopened after closing
  • Added fix for a bug that could cause RAM corruption when reading CPU registers on 5xx/6xx devices
  • UIF now starts up supplying 3V to target
现在已经有人分享licenses了,我的是最新的CCS5.2,可以用  详情 回复 发表于 2012-11-4 12:25
2453
CCS不好破解
用网上的破解不知道是否可以用
186
24
