附件上面的图就是signaltap抓到的图形。
还有算法实现程序在下面:
module sincos(clk,rst_n,ena,phase_in,sin_out,cos_out,eps);
parameter DATA_WIDTH=28; parameter PIPELINE=28;
input clk,rst_n,ena; input [DATA_WIDTH-1:0] phase_in;
output [DATA_WIDTH-1:0] sin_out,cos_out,eps;
reg [DATA_WIDTH-1:0] sin_out,cos_out,eps;
reg [DATA_WIDTH-1:0] phase_in_reg;
reg [DATA_WIDTH-1:0] x[PIPELINE:0]; reg [DATA_WIDTH-1:0] y[PIPELINE:0]; reg [DATA_WIDTH-1:0] z[PIPELINE:0];
reg [1:0] quadrant[PIPELINE:0];
integer i;
//get real quadrant and map to first_n quadrant always@(posedge clk or negedge rst_n) begin if(!rst_n) phase_in_reg<=28'd0; else if(ena) begin case(phase_in[27:26]) 2'b00:phase_in_reg<=phase_in; 2'b01:phase_in_reg<=phase_in-28'd67108864; //-pi/2 2'b10:phase_in_reg<=phase_in-28'd134217728; 2'b11:phase_in_reg<=phase_in-28'd201326592; default: ; endcase end end
always@(posedge clk or negedge rst_n) begin if(!rst_n) begin x[0]<=28'd0; y[0]<=28'd0; z[0]<=28'd0; end else if(ena) begin x[0]<=28'd81503715;// 0.60725*2^27 y[0]<=28'd0; z[0]<=phase_in_reg; end end
//level1-level26 //level1 always@(posedge clk or negedge rst_n) begin if(!rst_n) begin x[1]<=28'd0; y[1]<=28'd0; z[1]<=28'd0; end else if(ena) begin if(z[0][27]==1'b0) begin x[1]<=x[0]-y[0]; y[1]<=y[0]+x[0]; z[1]<=z[0]-28'd33554432; //45deg end else begin x[1]<=x[0]+y[0]; y[1]<=y[0]-x[0]; z[1]<=z[0]+28'd33554432; //45deg end end end //level2 always@(posedge clk or negedge rst_n) begin if(!rst_n) begin x[2]<=28'd0; y[2]<=28'd0; z[2]<=28'd0; end else if(ena) begin if(z[1][27]==1'b0) begin x[2]<=x[1]-{y[1][DATA_WIDTH-1],y[1][DATA_WIDTH-1:1]}; y[2]<=y[1]+{x[1][DATA_WIDTH-1],x[1][DATA_WIDTH-1:1]}; z[2]<=z[1]-28'd19808338; //26deg end else begin x[2]<=x[1]+{y[1][DATA_WIDTH-1],y[1][DATA_WIDTH-1:1]}; y[2]<=y[1]-{x[1][DATA_WIDTH-1],x[1][DATA_WIDTH-1:1]}; z[2]<=z[1]+28'd19808338; end end end //level3 always@(posedge clk or negedge rst_n) begin if(!rst_n) begin x[3]<=28'd0; y[3]<=28'd0; z[3]<=28'd0; end else if(ena) begin if(z[2][27]==1'b0) begin x[3]<=x[2]-{{2{y[2][DATA_WIDTH-1]}},y[2][DATA_WIDTH-1:2]}; y[3]<=y[2]+{{2{x[2][DATA_WIDTH-1]}},x[2][DATA_WIDTH-1:2]}; z[3]<=z[2]-28'd10466181; //14deg end else begin x[3]<=x[2]+{{2{y[2][DATA_WIDTH-1]}},y[2][DATA_WIDTH-1:2]}; y[3]<=y[2]-{{2{x[2][DATA_WIDTH-1]}},x[2][DATA_WIDTH-1:2]}; z[3]<=z[2]+28'd10466181; end end end 。
//level26 always@(posedge clk or negedge rst_n) begin if(!rst_n) begin x[26]<=28'd0; y[26]<=28'd0; z[26]<=28'd0; end else if(ena) begin if(z[25][27]==1'b0) begin x[26]<=x[25]-{{25{y[25][DATA_WIDTH-1]}},y[25][DATA_WIDTH-1:25]}; y[26]<=y[25]+{{25{x[25][DATA_WIDTH-1]}},x[25][DATA_WIDTH-1:25]}; z[26]<=z[25]-28'd1; //1deg end else begin x[26]<=x[25]+{{25{y[25][DATA_WIDTH-1]}},y[25][DATA_WIDTH-1:25]}; y[26]<=y[25]-{{25{x[25][DATA_WIDTH-1]}},x[25][DATA_WIDTH-1:25]}; z[26]<=z[25]+28'd1; //1deg end end end
always@(posedge clk or negedge rst_n) begin if(!rst_n) for(i=0;i<PIPELINE;i=i+1) quadrant<=2'b00; else if(ena) begin for(i=0;i<PIPELINE;i=i+1) quadrant[i+1]<=quadrant; quadrant[0]<=phase_in[27:26]; end end
always@(posedge clk or negedge rst_n) begin if(!rst_n) begin sin_out<=28'd0; cos_out<=28'd0; eps<=28'd0; end else if(ena) case(quadrant[27]) 2'b00:begin sin_out<=y[26]; cos_out<=x[26]; eps<=z[26]; end 2'b01:begin sin_out<=x[26]; cos_out<=~y[26]+1'b1; eps<=z[26]; end 2'b10:begin sin_out<=~y[26]+1'b1; cos_out<=~x[26]+1'b1; eps<=z[26]; end 2'b11:begin sin_out<=~x[26]+1'b1; cos_out<=y[26]; eps<=z[26]; end endcase end endmodule
中间省略了一部分流水线。
希望哪位高手能给我说下问题,万分感谢啊。 |
