void delay_1us(void)
int sec;
for(sec=0;sec<8;sec++)
_NOP();
void Transmit_Start(void)
P9DIR|=0x02;
SDA_1(); SCL_0();
delay_1us();
SCL_1();
delay_1us();
SDA_0();
delay_1us();
SCL_0();
delay_1us();
SCL_1();
delay_1us();
SDA_1();
delay_1us();
SCL_0();
void Connection_Reset(void)
unsigned int i;
delay_1us();
SDA_1();
delay_1us();
SCL_0();
delay_1us();
for(i = 0; i < 9 ; i++)
SCL_1();
delay_1us();
SCL_0();
delay_1us();
Transmit_Start();
char Write_Byte (unsigned char value)
unsigned char k,error=0;
P9DIR|=0X02;P9REN&=0xFD;//1OUT
delay_1us();
for(k=0;k<8;k++,value<<=1)
if(value & 0x80)
SDA_1();
else
SDA_0();
delay_1us();
SCL_1();
delay_1us();
SCL_0();
delay_1us();
P9DIR&=0XFD;P9REN|=0x02;P9OUT|=0x02;//9.1Input with pullup resistor
SCL_1();
delay_1us();
error =P9IN&0X02;
SCL_0();
delay_1us();
P9DIR|=0x02;
delay_1us();
SDA_1();SDA_1();
return error;
char Read_Byte(unsigned char ack)
unsigned char i,val =0x00;
P9DIR&=0XFD;P9REN|=0x02;P9OUT|=0x02;//9.1输入模式,选择上拉电阻
for(i=0;i<8;i++)
val<<=1;
SCL_1();
delay_1us();
if(P9IN&0X02) val =(val|0x1);
SCL_1();
delay_1us();
P9DIR|=0X02;P9REN&=0xFD;//9.1 OUT
delay_1us();
if(ack==1)
SDA_0();
else
SDA_1();
_NOP();
SCL_1();
delay_1us();
SCL_0();
delay_1us();
delay_1us();
return val;
char Measure_Mode(unsigned char *P_Value,unsigned char *P_Checksum,unsigned char Mode)
unsigned char error=0;
unsigned int i,j;
Transmit_Start();
switch(Mode)
case 0: error+= Write_Byte(measure_temp); break;
case 1: error+= Write_Byte(measure_humi); break;
default: break;
for(j=125;j>0;j--)
for(i=65535;i>0;i--)
if(P9IN&0X02==0) break;
if(P9IN&0X02) error+=1;
*P_Value =Read_Byte(ACK);
*(P_Value+1) =Read_Byte(ACK);
*P_Checksum =Read_Byte(noACK);
P9DIR|=0x02;
return error;
void Cal_SHT11(float *P_Temp,float *P_Humi)
const float C1 =-2.0468;
const float C2 =+0.0367;
const float C3 =-0.0000015955;
const float T1 =+0.01;
const float T2 =0.00008;
float rh =*P_Humi;
float t =*P_Temp;
float rh_near,rh_true,t_c;
t_c =t*0.01-40.1;
rh_near =C1+C2*rh+C3*rh*rh;
rh_true =(t_c-25)*(T1+T2*rh)+rh_near;
if(rh_true>100) rh_true=100; //cut if the value is outside of
if(rh_true<0.1) rh_true=0.1; //the physical possible range
*P_Temp =t_c; //返回温度
*P_Humi =rh_true; //返回相对湿度(rh%)
void Data_To_String(SHTscatter *Time,float DATA,float DATA1)
unsigned int i;char gewei,shiwei;
i=(int)DATA;
shiwei=i/10;
gewei =i%10;
Time->DATAstrings1[0] = shiwei + '0';
Time->DATAstrings1[1] = gewei + '0';
i=(int)((DATA-i)*10);
Time->DATAstrings1[2] ='.';
Time->DATAstrings1[3] = i + '0';
Time->DATAstrings1[4] = '\0';
i=(int)DATA1;
shiwei=i/10;
gewei =i%10;
Time->DATAstrings2[0] = shiwei + '0';
Time->DATAstrings2[1] = gewei + '0';
i=(int)((DATA1-i)*10);
Time->DATAstrings2[2] ='.';
Time->DATAstrings2[3] = i + '0';
Time->DATAstrings2[4] = '\0';
void Show_Tehu(void)
SHTscatter S;
SHTValue Temp_Value,Humi_Value;
unsigned char error,checksum;
error =0;
error =Measure_Mode((unsigned char*) &Humi_Value.i,&checksum,1)+error; //湿度
error =Measure_Mode((unsigned char*) &Temp_Value.i,&checksum,0)+error; //温度
if(error!=0)
Connection_Reset();
else
Humi_Value.f =(float)Humi_Value.i;
Temp_Value.f =(float)Temp_Value.i;
Cal_SHT11(&Humi_Value.f,&Temp_Value.f);
Data_To_String(&S,Temp_Value.f,Humi_Value.f);
PutStringEN24(188,200,S.DATAstrings1); //温度值
PutStringEN24(140,200,S.DATAstrings2); //相对湿度值(%)
