2552|1
求助有关定时器A 中的TAR。 [复制链接]
小弟写了一个测量方波频率的程序,但是TAR中值一直为0.求帮助。下面是代码。
#include
long time[8];
double sum;
long period;
long frequency=1;
long i=0,j=-1;
void process (void);
void delay ();
void main (void)
   WDTCTL = WDTPW + WDTHOLD;
   BCSCTL1 = CALBC1_1MHZ;                           // Set range
   DCOCTL = CALDCO_8MHZ;                          // set DCO step + modulation
   BCSCTL3 |= LFXT1S_2;                                  // Set LFXT1
   BCSCTL2 |= SELM_3 + DIVM_3 + DIVS_3;
   P1DIR &= ~BIT2;
   P1SEL = BIT2;
   TACTL = TASSEL_2+ID_0+TAIE+MC_3;
  CCTL1 = CM_1+SCS+CAP+CCIE;
   _EINT();
    delay();
    process();
void process (void)
{  while(j<7);
   for (i=0;i<=6;i++)
   sum += time[i+1]-time ;
   period=sum/7;
   period=period/1000000;
   frequency=1/period;
#pragma vector=TIMER0_A1_VECTOR
__interrupt void timer_a(void)
   switch(TAIV)
      case  2:
        time[++j]=TACCR0;
              break;
   if(j==7)
   CCTL1 &= ~CCIE;
void delay ()
  unsigned int i;
  unsigned int j=10;
  for(i=10;i>0;i--)
    while(j--);
2452.h 的头文件
