3769|6
各位大哥 高手 帮帮忙 [复制链接]
module flash_mod(clk,rst,LED_OUT);
input clk;
inout rst;
output  LED_OUT;
reg [19:0]cnt;
reg led_out;
parameter T50ms=20'd999_999;
always@(posedge clk,negedge rst)
  begin
  if(!rst)
  begin
   cnt<=0;
   led_out<='b0;end
   else if(cnt==T50ms)
        begin cnt<=0;
        led_out<=~led_out;end
        else cnt<=cnt+1;
        end
assign  LED_OUT=led_out;
endmodule
module run_mod (clk,rst,LED_OUT);
input rst;
input clk;
output [2:0]LED_OUT;
reg [14:0]cnt0;
reg [6:0]cnt_100ms;
reg [2:0]led_out;
parameter T1ms=15'd19_999;
//--------------1ms计数器----------------//
always@(posedge clk, negedge rst)
begin
    if(!rst)
      begin
       cnt0<='b0;
                 cnt_100ms<=0; //------100ms计数器----------------------------//
                 led_out<='b001;
       end
        //-------------每100ms移位一次-----------------//
          else if(cnt_100ms==7'd99)
         begin
                 if(led_out==3'b000)//判断是否移到末位//
                         led_out<=3'b001;
                      else led_out<={led_out[1:0],1'b0};
                   end
    else if (cnt0==T1ms)
                    begin
                        cnt0<='b0;
                        cnt_100ms<=cnt_100ms+1;
                        end
                  else cnt0<=cnt0+1;
end
endmodule
module top_mod (clk,rst,Flash_led,Run_led);
input clk;
input rst;
output Flash_led;
output [2:0]Run_led;
wire Flash_led;
flash_mod i1(.clk(clk),.rst(rst),.LED_OUT(Flash_led));
wire [2:0]Run_led;
run_mod i2(.clk(clk),.rst(rst),.LED_OUT(Run_led));
assign Flash_led =Flash_led;
assign Run_led =Run_led;
endmodule
quartus 仿真没有错误 但是modelsim错误 : ** Warning: (vsim-3009) [TSCALE] - Module 'flash_mod' does not have a `timescale directive in effect, but previous modules do.
#         Region: /waterlap_tb/i1/i1
# Loading work.run_mod
# ** Warning: (vsim-3009) [TSCALE] - Module 'run_mod' does not have a `timescale directive in effect, but previous modules do.
#         Region: /waterlap_tb/i1/i2
# WARNING: No extended dataflow License exists
此帖出自FPGA/CPLD论坛
确实如楼上所说啊,长期处于复位状态!  详情 回复 发表于 2012-5-9 19:04
752
仿真时间未定义
`timescale 1ns / 1ps 类似这样的定义,加在模块外面。
此帖出自FPGA/CPLD论坛
回复 沙发 deweyled 的帖子
版主您好 !这是激励模块 您说的timescale 定义是在外面的 而 其他的模块我没加 timescale
`timescale 1 ns/ 1 ns
module waterlap_tb();
reg clk;
reg rst;
// wires
wire Flash_led;
wire [2:0]  Run_led;
top_mod i1 (
        .Flash_led(Flash_led),
        .Run_led(Run_led),
        .clk(clk),
        .rst(rst)
initial
begin
clk<=0;
rst<=0;
#50  rst<=1;
end
always
begin
#25 clk=~clk;
end
endmodule
此帖出自FPGA/CPLD论坛
752
最好每个都加上
此帖出自FPGA/CPLD论坛
回复 4楼 deweyled 的帖子
感谢您 !错误是没哟哦 ,可还是输出 仿真波形 依旧是红线?请问怎么回事 ?在激励里 有清零
此帖出自FPGA/CPLD论坛
752
系统没有复位,你的复位信号没有满足系统复位要求。你可以根据代码分析下。
此帖出自FPGA/CPLD论坛
6892
鏌ョ湅鏈笘鍏ㄩ儴璁ㄨ锛岃鐧诲綍鎴栬€�娉ㄥ唽
此帖出自FPGA/CPLD论坛
个人签名一个为理想不懈前进的人,一个永不言败人!
欢迎光临网上店铺!
【直播时间】5月28日(周三)上午10:00
